Braek Booster Adapter??
my64fj40 said:
Who makes a brake booster adapter for a GM booster..
I remember seeing one somewhere but I am currently having a brain fart or something..
Maybe here.
Marksoffroad is mentioned, not sure if this is what you were looking for....
Assuming this is on your '64 FJ40? Are you going to cut the firewall brace or try to space out in front of it? If you are cutting it, I have seen guys just drill the GM pattern in the firewall and use no adapter. I made an adapter that bolts to the three-bolt Toyota-pattern and spaces my MC out enough to clear the rib, but I'm not boosted.
Is the booster bolt pattern the same as for a GM master? As in 2 bolt? If so I have anough parts to make another and would gladly send them to you. I just don't know what the GM booster bolt pattern is.
GL
Ed
The adapter I offer does indeed have a four bolt rectangular pattern on it, but I do not think it is quite as big as the bolt pattern on your booster would require. I suppose you could weld a different flange onto it, or I could sell you one without the booster end of the adapter, and you could add on your own plate.
You can call the shop to follow up if you're interested. My forum time is kinda spotty these days.:frown:
Best
Mark A.
