BP51- Rear squeak/chirp CURED 😌
Denver, CO, USA
I have a new to me truck (21 LC200 w 40k miles) where everything is perfect on it but it has a minor mouse squeak bird chirp that shows up at slow-moderate speeds driving over very slightly uneven parts of the road. Big speed bumps, no problem, but a minor imperfection in the road makes the truck squeak in the rear of the vehicle. I can’t pinpoint which side it’s coming from yet. I thinkkk it’s rear passenger. But a buddy will help me look tomorrow.
I took the truck to a local Toyota shop and they weren’t able to find the source of the sound. They referred me to a local Toyota off-road shop here since the suspension is aftermarket (OME BP51). I have that appointment in a couple weeks.
I have removed the spare from underneath and confirmed that’s not it. I checked to make sure the exhaust heat shields aren’t rubbing anywhere. The dust shields on the breaks seem fine. I can’t replicate the sound when it’s sitting in the garage. I believe I’ve noticed the sound appears when weight is removed from the frame (ie pumping brakes and thus weight shifts forward, away from rear.)
Here’s a video that just gives you an idea of the sound šŸ¤·ā€ā™‚ļø buellerrr? Anyone??
Sound starts at around 12 second mark above when I give the truck a few brake checks. The sound also happens running over little bumps when I’m not on the brakes at all.
I’m no suspension guru, but I’ve seen a number of posts on here about noisy/squeaky BP-51 shocks. Here’s one of many.
This is good reading material. Thank you. This seems like a likely suspect.
This video that the shop took makes sense now. It seems like there is play at the top shock mount area even though the nut is tight.
This is such a common issue and has been going on for so long, I really can’t wrap my head around why ARB/OME hasn’t addressed it.
The previous owner likely just had the shocks slapped on a few years ago, along with some other stuff, when this was a popular issue according to other threads and then just didn’t mind the squeak. Which is insane to me lol but whatever. I can’t ā€œjust turn the music up and ignore itā€
I get that, but to my knowledge OME is still shipping these systems this way and hasn’t updated the instructions.
I feel you. That would make me go nuts. šŸ˜…
Flex head 22mm rachet wrench made it easy peasy to come in from the outer fenders. Windows down, squeak free now :)
Case closed
This thread and the other referenced thread are very helpful. Really appreciate the part number for the replacement washer.
For any of you who have made the fix, is this as straightforward as it appears? Which is to say, could some one without access to a lift and tools beyond the set of craftsmans in the garage do this in his driveway?
As always, the insights from this board are amazing!
Agreed. A ton of good info in this forum.
A 22mm flex head ratchet makes the job extremely easy from the wheel well. Otherwise you have to get under the vehicle and fiddle with it a bit more. There isn’t much room around the exhaust.
I looked through your thread, Grouchy you posted different pictures of what the OP installed/changed. what did you change?
It’s a giant font in the middle of the post.
ā€œUse ALL your original Toyota parts EXCEPT for the OME bottom and top washers as well as the smaller diameter thick washer that sits directly under the nut.ā€
