BP-51 Install Problem
Greeneville, TN
Hey everyone,
I had a pretty serious issue happen last night as we finished installing the suspension. After lowering the lift, turning on the vehicle, and putting in reverse, started hearing a grinding sound coming from the right front axle, started about 1 sec after engaging. Turned it off, turned back on, back in reverse, same sound started about 1 sec after. We put it in neutral, and were able to rotate the right front wheel, but whole axle didn't rotate - the first linkage would rotate with the rotor assembly, but the next section would not.
Has anyone had a similar issue? And, how have you fixed it?
We didn't have, and at 12:15 am this morning, weren't able to find a 12 point 36 mm drive to take of the CV/wheel/rotor assembly, so we aren't real sure what the issue is.
Please help! And, thanks in advance.
By your description, it sounds like the axle has come out of the outer cv joint...
