Body Mounts...
Website
www.geocities.com
Hello once again,
I have a question about the body mounts. I am attatching the tub to the chasis. When i removed the tub, I saved the old rubber, but the bolts and holders broke. I purchased new nuts/bolts and intend on slipping the rubber between the tub and frame - then putting a nut through to hold it all together. My question is...Currently I have successfully been able to do this with only 6 mounts - the main ones - but do you think there will be great problems forseen in my future if I do not get all the mounts?
thanks...
Hi All:
The original body tub on my FJ40 was so rotted-out that some of the body mounts were not really attached to the body! This caused a bit of extra flex between the body and chasis, resulting in squeks, rattles, etc. Since swapping-on a solid rear body tub and replacing the body mounts with new poly units (Energy Suspension brand) the truck seems much more solid and quieter as well!
Good luck with the project!
Alan
Seattle
If you've gone to the trouble of pulling the tub I would replace the mounts. My old mounts were so cracked and dry rotted that I couldn't see using them again. If your mounts need new bolts and nuts I'd say they were shot.
I used the mounts sold on CCOT http://store.yahoo.com/coolfj40/bodymounts.html
Here's a picture of them under my Cruiser
ya dont half ass the job, get them all in. you air all your tires up the same right.
bandy rooster said:
hey toyo nice truck... cleannnn
fj40onnos - i can never understand a damn sentece you type....
what do you mean??
you dont air 2 tires to 35 and leave 2 at 25
Not to hijack, but has anyone used the 1" Daystar kit? :confused:
Ed
Ed
i almost did till i found the back of my Cruiser all welded up, well more halfass welded so i had to just finish welding it and clean up!
IH8THEPO
IH8THEPO
You mean like welded to the frame???? Ya gotta love some of the PO Engineering.:frown:
Ed
go for the new mounts even i splurged for the new mounts and i cut corners every where ! anything to save a penny, they are always on ebay , i got a bodymount kit with one inch spacer can't remeber from where i think specter , i added a 2 inch block to make it a 3 inch bodylift . heres a pic of the polyurethane mount . very easy to install and no messin around with rusty bolts ,
body lift was not an issue for me because i'm using sag power steering . and for the tranny transfer . the sm465 liked the extra room needed no mods , and for the transfer case shifter i just had to slightly enlarge the hole in the tranny tunnel . everything worked out fine for me in my rig . but my rig is slightly modified from stock . i did run a 2 inch bodylift with stock steering . just had to slightly lower the steering column at the firewall , and spaced the steering box up using longer studs and spacer between box and mount , kinda mickey mouse tho
iam_turner said:
PBGbottle,
when you did the body lift of three inches, did you have to mess around with your steering linkage and transmission linkages?
thanks...
Hi All:
Hey "Hijack," why does it appear that your body tub is riding on top of 8 (?) leaf springs? ;-)
Alan
Seattle
