Body Mounts Bolts
Al Ain, UAE
Today was checking around under my truck, and I thought I'd see if the body mounts were tight - the bushings looked fine, but you know while I was there...
Anyways, to my surprise it tightened very easily with a wrench! So I kept tightening it until it became clear it was just turning empty. So I tried the one on the other side (front ones, frame to body, just behind bumper) and the same thing happened!
So, what's above these bolts? A welded nut? I couldn't get to see nor feel.
They're supposed to be on tight, right?
No welded nut. You have to hold them with a wrench on top.
I found the same - was looking to tighten the one under the driver's seat. Turned freely and gave up. Later found you have to pull the carpet back and put a wrench on it. Some day.
DougM
Would an air-powered tool be able to tighten it without holding the top nut? A buddy said it would have an impact-like action that would not require holding the nut in place...
Anybody know if an impact wrench can tighten/loosen the body mount bolts without having to secure the nut? I don't have one to try, but the tire shops here have them so I could borrow one. Sorry to repeat, but I got no one else to ask :)
prossett,
You'll need to gain access to the bolt heads. The impact won't cut it on it's own. With the exception of the mounts under/near the driver and passenger seats all can be accessed reasonably easy. To access the two rear mounts you'll need to pop off the plastic covers (covers directly above the mount as you're looking aft). I don't recall the markings on the bolt heads but when I installed my body lift using Grade 5 bolts (similar to the 8.8 bolts used) I torqued them to 30 ft. lbs (~41 Nm). Have not had any issues yet.
OK, thanks - I'll shop for a body lift and do that at the same time, then. I had the carpet off just last month... and didn't do it :confused:
