Well so far got all the mounts off except one: passenger side under the step support. This rig was missing 3 body mounts! Anyway, spent one hour dremeling the bolt head; didn't cut the shaft just ruined the head. Broke out the BLUE WRENCH, torched the remaining shaft off (ill advised; close to gas tank and lines so I had to set up a fire barrier but still not the smartest.) But now a molten mass of metal and burned rubber is stuck up in the square tubing and hard to get to with a chisel. Will approach this problem when I'm fresh. Maybe an air chisel or something. Gee...now I need a bigger compressor. Turning into a real PITA.
