Body lift?
Philipsburg PA
So... I'm looking for a 1" body lift kit for my rig and I can't find one on eBay. The reason is because I'm thinking of running 37's verse 35's. I don't even know if they full fit. Lol. I got the 3" ome lift kit and I'm not sure if 37's will fit with an extra inch body lift. Wich I can't find anyway. I dont want to cut or trim. And if they don't won't fit I'm not going to want a body lift and I'll just stick with 35's. Input?
I have 37x12.5x16s with 4 inch suspension 2 inch body lift
I wheel it hard for a road truck with no rub and have half decent wheel travel up and down.
I had to extend bumpstops 75mm to stop tyres rubbing on inner guards
And got wheel offset changed to +38 (16×8) so tyre tucks in guard without touching wheel arch and inside of inner guard.
I am running after market radius arms which centre front wheels in wheel arch
Setup you mention would be ok for road use but off road wouldn't work
That's a lot of information, what seems to be the preferred setup?
Aluminium??, HD hardware??, shift extention??, radiator drop??
I have a couple of posts in my build thread with other links that I found very informative.
As well as getting the right wheel offset, I believe tyre width is a significant factor in what will and what won't work with the proposed set-up. I have a 2.5 inch OME suspension and 1 inch body lift running 255/100r16 (measure a true 36 inches like many '37s' but only 10 inches wide). With extended bump stops I have little to no rubbing and acceptable up/down travel. I think the proposed set-up could work....
One of the spacers is very near the exhaust and needs to be metal. The rest can be plastic.
The SAE hardware is said to be better than the metric. This makes no sense to me because metric class 10.9 is ever so slightly stronger than SAE grade 8. And there is also metric class 12.9 which is stronger still. Maybe they're offering SAE grade 8 or metric class 8.8 (which is similar to grade 5) -- in a body mount it probably doesn't matter.
At 1 inch you don't need a shift extension that i know of.
The bolts are 3/8" by 5", 5.5" & 7". The 7" are for the front & 5.5" for rear. Don't get them mixed up like I did.
Here on mud there is a very detailed thread that was very informative with good pictures.
Definitive 1" Body Lift How To
