Body frame and engine swap.
Grand Lake, OK
My 91 FJ80 was acting up. I followed @jonhelds poopy parts to replace list and had no luck. It took 40 seconds to reach 60mph. So I’ve amended the 3fe tune up list.
On Craigslist I found just the parts I needed. I had a sneaking suspicion that it was the frame, engine, and wiring harness. Which I swapped, then I swapped the body after that. Now everything works great! :)
Here’s the old and the new.
Here I am swapping the frame. Wear gloves. This is a good time to make sure your tranny fluid tastes fresh.
When you replace the tranny gravy make sure it is “conflict free”.
This is the third fuel tank, I usually burn off brand Kool-Aide in mine. It helps satisfy the engine. You can also put a variety of Campbell’s Chunky soups in here. But not Progresso, progresso is not OBDI compatible.
You’ll want to hold your Kool-Aide injector like a girl when you take it out. Make sure you have a cool overland compatible bracelet on.
If you’re guessing, yes I was pumping some bicep curls in between wrenching. I like to intimidate the neighbors.
Swap complete. You’ll want to change the PHH during the engine or body swapping phase. I did it afterwards because I’m a bad mother fxxxer.
The old one is $1500 if you are in Oklahoma. I paid that much for the AFM alone. I think.
I see your problem. The magnetic bowl stuck to the front fender will cause all the issues you described. All you had to do was remove that bowl and all your problems would have been resolved. Newbie mistake.
I do; however, really like the final results. It even looks newer. How did you update the grill, pictures and a write us please.
Comet.
Comet.
^^ this. It's pretty obvious as we have all seen them in the movies, albeit a more sophisticated version, but same results.
