- Joined
- Oct 28, 2011
- Threads
- 1
- Messages
- 4
Finally getting into several toyo truck projects, the first being reworking an 82 4 wheel drive truck with bad engine and body rot. My plan is to install a just built 22 re engine and the 2wd cab and bed that the engine came from. I notice that the frame to body mounts are about an inch further apart on the 2wd body (a 92 model) but I can fab something to cure that. Any other issues I should be aware of? Thinking of using a 1 or 2 inch body lift, and maybe cutting the front fenders or using 4wd fenders. I also have an 85 2wd and an 89 or 90 4wd cab but they are not as solid and rust free and am hoping to build one or both of these later. I want to use the 92 cab and all wiring to simplify the change to fuel injection. Thanks for any and all ideas/comments even like "you must have bumped your head".
