Boards Are Off
Avon Lake, Ohio
Well , "Beno - Onur" and I took the boards off the 95.
Due to the Ohio rust deposit on the nuts and bolts we had to take a side trip to my companies maintenance garage and cut the last of them off.
I must say it does look better. Now Onur is after me to do a OME 2.5 lift and put sliders and a ARB bumper on it before he relocates somewhere more interesting than northern Ohio. But first I need to replace the birfs. Then maybe we will go on a replacement program.
Thanks Onur, your ability to wrench, cut and hit with a hammer are legendary.
Be careful with those flaps. If you go wheelin' you might want to take them off. When they get between your tire and a boulder they will tear right off. I ended up trimming mine back quite a bit so I wouldn';t have to fix 'em again.
That truck is not a wheeling vehicle....yet...right Dr.?
I must admit I forgot what a boarded 80 series looked like before and after. It looks much better without the boards....
But I think both the Dr. and myself are sick of OH rust....:crybaby: :rolleyes:
Definitely got more to do before I leave OH Dr....don't worry, we'll set you and your son up before I leave.
Its locked. Maybe you should take him out to Wellsville. :eek:
Dang, I keep telling the wife how much better our cruiser would look w/o the boards. Maybe I can convince her to go with the Slee step sliders....
Does she actualy step on the boards?
Drsales, it looks as if we're on the same page. I took the runners off my truck last week, and this week it's getting new birfs (Longfields). Then the lift, new tires, and an ARB bar.
I love the look of the runner-less truck. Makes it look less bloated. Once the flares arnd spare are gond from mine, it'll look like a real off-road vehicle. :cool:
Apparently, yes. I never do.
Try telling her that the grab handles are for getting in and out of the truck and the running boards are aesthetic to make it look closer to the ground. Maybe she'll bite. :D
i've thought about doing this for awhile....seeing those pics sold me
is it as easy as just getting under there and just start removing stuff?... i've got airtools so i figure that should help a bit with rust and the like
Spray the bolts down with penetrating fluid the day before you do it.
I think it took me like 45 minutes to an hour to pull them off. It took me quite a bit longer to finally score the front mud flaps. I replaced the rear flaps with shorter ones from an earlier model and trimmed the fronts all to avoid ripping them off on the trails.
I had to put the running boards back on while my wife was pregnant. My arm still hurts from my suggestion she use a stool.:grinpimp:
The rust did a number on the bolts. All in all it took use about 3 hours. We had to head over to my company and grab a torch to cut a few bolts off that had gone bad.
Funny...mine are stuck on with "Wife Rust" also. That's some pretty strong stuff...She claims she can't buckle the daughter in the car seat.
