blue smoke when changing gears
greenville, nc
when I am driving my fj40, I have noticed that a small amount of blue smoke exits the exhaust when I shift gears. The engine has at least 117,000 miles on it but I am not for sure because the speedometer was frozen when I got it. I put new valve seals in the engine when I redid the body 3600 miles ago. The engine will consume appoximately one quart of oil in 3000 miles, however it does not run poorly and I have not noticed it smoking except when shifting gears. I noticed this condition when my drivers side mirror was loose and rotated down while I was driving one day last week. I am going to check the compression to see what it is but I was wanting your opinions. I think that the problem may be in the valve guides, but I am an amateur at best.
1974 FJ40 stock f engine as far as I know 117,00 miles
will
Black smoke = carb too rich
Blue smoke = burning oil
White smoke = burning water/coolant
Sure it's not black smoke - running rich? If it's burning a little oil but otherwise okay - I'd leave it be and continue on enjoying it. The rings are probably just a bit worn. Maybe run a little thicker oil - 20W50? All cars burn oil - so what if yours burns a little more.
I'd do a compression check like you mentioned and if it checks out without any catestrophic differences in compressor - continuing driving it.
Between gears as rpms drop, the engine pulls a lot more vacuum. Valve guides, PCV valve, anything that can suck oil will cause blue smoke. My cruiser has no emissions stuff, but I had an MG that started smoking like a banshee when pulling a lot of vacuum. It turned out to be a ruptured diaphragm in the "gulp valve"....a $15 fix.
I have no idea if Cruisers ever had a gulp valve. All manufacturers threw a lotta stuff on engines to make them smog legal.
Worn valve guides can be diagnosed with a vacuum gauge. PCV valve is easy to check, clean replace if necessary.
GL
Ed:beer:
right now i'm running 10w40 engine oil. I don't think it is a carburetion problem because of how well it runs. will the weight of the engine oil make a noticeable difference? Like i said earlier, i am a noob.
will
will
Quit saying you're a newb - you'll give yourself a complex :flipoff2:
Hopefully its as simple as the PCV valve like the others have stated. If not, switching oil to a thicker weight should help curb the consumption a little. Most run 20W50 all year long - unless you're in the frozen Tundra. . .
Good luck and let us know what you find.
what is acceptable compression - 140-160 psi?
what is the minimum - 120 psi?
Minimum is 90psi or thereabouts. <90=dead cyl.
Max varies with year but anything in the 135-145 would make me happy and think the motor has a lot of life left in it.
Lower compression =lower vacuum, too.
Didja check the PCV? Worn valve guides usually cause smoke on startup, but not usually between gears.
Did this start all of a sudden?
GL
Ed
i'm going to check the pcv. I just noticed it, but I don't know for sure how long it's been going on.
