Blue smoke on cold startup
San Diego, CA
96 Land Cruiser.
On a cold start, there is a puff of blue smoke out of the exhaust.
There is no blue smoke on acceleration or load which would indicate rings.
There is no blue smoke after idling (any amount of time) or after hot starts, which would indicate valve seals.
On my LS400 the power steering system is somehow connected to the intake and causes similar blue smoke.
The truck has brand new valve stem seals.
Any ideas?
pcv valve, take a look at the crank case vent something is causing oil to drain down, How many miles on the motor??
Did you use toyota valve stem seals? How long ago was the head off the engine and what made you pull the head in the first place? Mine did the same thing at start up and is the main reason I decided to pull the head for R@R. Now no smoke and the engine does not consume oil.
When I was supposed to be a Honda/Toyota Mechanic, I was probably a bit blase' about a lot of things. I was lazy about spending customers' money, as I still am. If it is not a real problem, I hesitate to throw money at it. I am still that way.
I did this for a living for 20 years, and I was supposed to find problems to spend money on. But I don't want to. I never did. If it works, don't fix it!! A bit of the blues on a cold morning is normal.
My 96 does the same thing, and has for the last 50k, ever since I've had it. I look in the mirror, saying, "It's got the blues again!" It doesn't like cold weather. It smokes when it is made to work in the cold. Wouldn't you? When I have to work out in the cold, I cuss a blue cloud! You don't want to hear me at all! Why should my truck be different? Yet my truck is different. Once it gets warm, about 1-2 minutes, the blues are gone. No problem. If I have to be outside in the cold, I don't warm up. I cuss a blue cloud all day! My truck warms up, but I never do!
Valve stem seals!:bounce::bounce2:
valve stem seals. typical toyota with overhead cam. don't worry about it.
I just replaced the head gasket and installed new valve seals five months ago. It's been fine ever since. Just started doing this recently.
Did you use Toyota valve stem seals?
As for the problem on your LS400... there is a valve on the PS unit that has vacuum hoses going to the intake. That valve is a well known problem and will start leaking around 100k. Eventually, it will start leaking PS fluid all over the place, including the PS fluid getting burned in the engine and causing your "blue smoke" in the mornings. Get the p/n and give Cruiserdan a call. The part is ~$300 at your Lexus dealer and ~$80 from Dan (I can't recall the actual prices but that gives you an idea of the savings.) R&R is a DIY project and only takes about 1 hour if you are slow. Let me know via PM if you need more information.
-B-
Hi guys,
You'll have to pardon my ignorance, but please explain R&R? :rolleyes:Thanks,
R&R = Repair and Replace, or variance of same
Outside of Mud:
R&R Rock and Roll (music)
R&R Rest & Relaxation
R&R Rules and Regulations
R&R Resource and Referral
R&R Read and Review
R&R Rest and Recuperation
R&R Read & Review
R&R Radio & Records, Inc
R&R Repeatability and Reproducibility
R&R Recruitment & Retention (human resources)
R&R Relief and Rehabilitation
R&R Resettlement and Rehabilitation (India)
R&R Remove & Replace
R&R Repair and Replace
R&R Reward and Recognition (human resources)
R&R Refuse & Resist! (non-partisan, national membership organization)
R&R Remove and Reinstall (computer software)
R&R Repairs and Restoration (various organizations)
R&R Rest & Recreation
R&R Rest & Recuperation
R&R Response & Recovery (FEMA)
R&R Retention and Release (NASA)
R&R Repair & Return
R&R Repeatability and Reliability (statistical analysis)
R&R Roles and Responsibility
R&R Refit and Repair
R&R Rock and Rye (bar drink)
R&R Receiving and Release (prisons)
R&R Repair & Renewal
R&R Research & Reconnaissance
R&R Review and Revalidation
R&R Rest & Romance
R&R Removal and Reassembly
R&R Rebutted and Rejointed (roofing shingles)
R&R Rate and Review
Have been dealing with startup smoke for years now and its gotten worse.
Short of replacing valve stem seals I have found that using Lubro-Moly Motor Oil Saver with MoS2 Antifriction Motoroil 10 W-40 has the least amount of startup smoke of any oil and or additive combo I have tried and I have tried many.
I am betting its the Motor Oil Saver additive that is doing the work as after a several thousand miles I get startup smoke again. I then just add another can. You can tell the difference too at the dip stick. You can see how the oil clings to the dip stick. It somehow climbs up the dipstick. It think it actually is sticking in the dip stick chamber after the you shut off the motor unlike motor oil where it would just quickly drain down.
The 10w40 with Oil Saver is TOO thick for winter use so I am back to Rotella T 5w40 and startup smoke. When the weather warms up I will try Oil Saver with the Rotella T.
If you live in areas with smog check there are "smokeless" motor oils like FHS SmokeLess Oil and ENTEK Smokeless Motor Oil. Guys on Bobistheoilguy.com have had luck with it. Have not tried them yet as they are $$ and Motor Oil Saver is very cheap and working for me.
Thanks Western Flyer - That is what I thought it was (in MUD), although the other connotations were very educational! Now I realize that Beowulf's reference to R&R was regarding the PS Valve, whereas the R&R that other people were talking about originally was the valve seals, which logically would take longer.
I think my head R&R is becoming more and more of a reality with the blue smoke on takeoff and the carbol buildup which is causing it to ping on low revs under load. Just have to decide when to do it...
Have a great week all of you!
I know this thread is hella old but this made me Crack up.....
