Blown Motor?
Nashville TN
Hay all my 91 fj80 just died! All the oil just came gushing out. It looks to be coming out of the left side towards the back of the block. Is this a head gasket or is my block cracked? Motor has 340k on it. Anyone in the Nashville tn area have any leads on 3fe motors available? Thanks
That doesn't sound good ,a head gasket wont normaley do that.
does it still run?
and ifso how does it run.
any water in the oil?.
Check the cam covers.
I doubt this is it, but just in case...
My only experience with a vehicle having sudden oil loss like that was when I had accidentally doubled up the oil filter seals on a '91 Escort.
Had you recently changed the oil?
Is the filter tight? Does the filter have at least one but not more than one seal?
I could see how a filter seal failure while driving could paint everything back of it and make it look like the oil was coming from the rear of the engine...
Just a wild guess/place to look.
Is there any chance you could post up a few pictures of what you are seeing?
does it still run?
It starts up okay. I did not even notice any difference while driving. As soon as I parked it my wife said I was Leaking something. As soon as I got out to look at it 8 qts of oil were under the truck. I started it quick so a friend could see were it was leaking. He said it was a head gasket. My mechanic said my block is cracked but he has not see it. No water in the oil that I can see. I have not checked the cam covers.
I just changed the oil on monday. I looked at the filter and around it and all is dry (relatively speaking) I will take some pics when I get a chance. The truck is parked at my wife office. Going to run back over there now to do some more research.
I've never seen this, but I've heard of expansion plugs popping out of 3FEs.
Had a good motor I shipped out to some dude in Florida who sent it to a junkyard because he and his friends thought is was "bad," if yours is smoked sorry you missed out on this one. But who knows maybe he was fibbing and still has it??
And just like Grench's Escort, the 3FE uses a Fram PH8A or equivelant which are notorious for leaving the old o-ring behind when removed. It is possible your oil leak is coming from between the two o-rings when the engine is running, and leaving the filter clean. JM .02
I just changed the filter on monday pulled off a mobile 1 no O-ring was left behind. I talked to 2 mechanics and was told I had a crack in the block. No coolant / water mixed in with the oil. Was quoted over 9k for a new motor and 4+k for a rebuild with a 30 day warranty. LOL I now some people who know some people that made a call and found me a motor for 1,200. At this point I have a Cruiser in the garage with a blown motor.
did u finde out where the oil was coming from?
If u havent located the cause of the oil leak u cant make a possitive diagnosis of "blown motor".....Blocks dont just crack!
There has to be a cause for the crack.
just my.02
I'm in nashville if you need any help. I know what the problem is, 99 percent sure.
Oil galley plug came out. There's tons of info on it in the 60 series forum. Theres a pressed-in plug near the #5 spark plug, when they come loose, all your oil drains out. Design flaw from Toyota.
Hopefully you caught it in time and did not ruin the motor!
The fix is put a threaded plug in that spot, supposed to be very easy.
Blocks don't crack without a reason, especially on such a low output motor like the 3fe. It's even rare for the 2jz blocks to crack while running anything under 600hp. I'm not saying it's not possible, just highly unlikely the block cracked. I would get a good diagnosis before I pulled that engine. Buy some super cheap oil and dump it in there and go to work finding the leak.
just my.02
I don't think It is cracked either that just does not make any since.
I think you are right. The leak is around the number 5 spark plug above the starter. I have not seen the leak myself and have not had the opportunity to dump any more oil in there and go searching. I agree with you guys theses blocks just don't crack. I think the motor is fine. Thank goodness I had to take the day off from work yesterday. I can't imagine what would have happened if that plug popped out on the interstate.
Gents thanks for all the help diagnosing this for me. This Forum is awesome the knowledge and know how is amazing. I don't have much cash to throw around and if it's only the galley plug you all just made my day.
Bryan062087 I will have to buy you a beer at the Yazoo Tap Room some time.
Thanks again you guys once I find out for sure I will post up the results. I won't have time until Sunday to dig into this.
x3 oil galley plug.
You said it was on the left side (US driver side) though, yet the oil filter and oil galley plug are both on the right side (US passenger side)...
If you're referring to the US passenger side as the 'left' side (standing in front of and facing the truck), then it's definitely the oil galley plug.
x3 oil galley plug.
You are right I was standing if front looking at it. Oil galley plug is what I'm going with.
