block & crank interchangeability
Godwin
Resident Herpetologist
Alabama
I'm trying to sort out the block and crank swappability across years and this relates to merbesfield's need for a good 2F block. Specter shows this:
Crankshaft Kit-REGROUND-Fits 9/73-10/84
and this:
Crankshaft-REGROUND-Fits 10/84-8/87.
The same production break is seen with the 2F blocks, but will a 9/73-10/84 crank work in a 10/84-8/87 block?
I have a later block ('86) and merbesfield has a good crank but it's a '78 so the question is whether or not these parts will work together.
The only differences are the main thrust bearings.... nothing to do with the crank itself as they are interchangeable from '69 to '87, but the 10/'84 up block is up-graded to accept the 6 piece main bearing thrust.. thats where the block change is...........
Ok, so 78 main bearings will not work in a later (10/84 up) model block unless you buy the 6 piece main bearing thrust, what ever that looks like? So will the crank from the 78 work in the later block if you buy later bearings? or do you have to have the bearings and a later crank to match the later model block? Confused yet:confused:
Here's a pic of the later 6 piece thrust bearing config. minus the top and lower shell.... shaft it self is interchangeable........
I think you have to have it at least shaved to fit those thrust washers in. or maybe its that you have to shave the later crank to fit the earlier thrust bearing in. I have been thru this before and but don't remember for sure. I do know that I had to have the thrust journal on the crank in my 60 widened to fit into an 84' block. I guess it could have been because of the brand of bearing.
Nothing to it really...... get the block you want and then get the main-brg set with the correct thrust bearing.....
There's no confusion. All F/2F cranks will fit in all blocks.
All F/2 blocks will accept the 1-piece thrust bearings.
The 85-later blocks have a tang machined out to accept the torq tang on the separate thrusts, but the earlier thrusts still fit.
The only architectural difference in cranks is the smack-on balancer or the bolt on balancer.
Re: the thrust machining. Some replacement undersize bearings have thicker thrust shoulders which requires machining the crank thrust to fit, just as the other bearings will need machined to fit undersize bearings. The factory thrust dimension does not change.
HTH.
Jim, I think I follow you. Any block will work with any crank, the only difference would be the later blocks would require the extra "torq tang", which I am guessing are the two extra parts when you look at the part count difference between years. Now, because I have already purchased 78 model bearings and would prefer to not have to return them I need to look for a block that is pre 85? Or I will need to buy the later bearings with the extra piece? Do I have that correct? Also, my crank has been measured and is still within factory specs as new so it does not need any grinding. I also looked at my conn. rods and they are the later forged ones for what it is worth as seen in these pics posted on mud. The one on the bottom pic.
HTH.
Thanks Big Boy!:bounce:
I believe its all self explanatory that the cranks are all the same, and the later block only excepts the later thrust mains.........:idea:
Mark,
I have a 4/84 block down here in AL, all you have to do is come get it. No need to purchase anything else and it's tapped for the PS pump mount.
Perfect. I will PM you. Maybe Friday? Need to find a sucker to ride with me. I tend to fall asleep on the road, not good.
