Block cleaning questions?
Pensacola, Fl.
I have my motor torn down, just the block. I'm concerned with the bearing on the front of the motor. Is it an issue for machine shops to replace this bearing? Should I just leave the bearing and clean the block myself?
Thanks Pin Head, You are a wealth of knowledge! :cheers:
I see in the FSM it says if the bearing is damaged to replace the block! :mad:
Seems like it wouldn't be much different than replacing a cam bearing in a Domestic V8.
Actually, any decent shop can replace the bearing. Many OTR and industrial engines use similar bearings or sleeves for different components. Either babbitt or oil impregnated bronze can be used.
After hot tanking and the evapo-rust treatment, my OEM bushing was toast when I rebuilt my engine last year. It took no time at all to make a new one.
Please elaborate on how you replaced the bearing?
The machinist measured the diameter of the hole in the block, measured the idler shaft and built a new one from a piece of billet. Thats way over simplified, but like I mentioned earlier, a skilled shop can make one without a problem. If yours is still intact, it can be measured (or even removed) before it is tanked.
Thanks Mud, Now if I can only find a "skilled" machinist! There are plenty of machinist's in my area, finding a skilled one is the trick...
I would look for a shop that specialises in Diesel repair. If nothing else, call around and ask if a shop can do what you need.
