Blinking Dome Light
Palm Harbor, FL
OK this is one of those annoying things that my cruiser just started doing.
Let me start by saying I have not done any electrical mods so what ever is going on is OE problem.
When driving down the road with the doors locked/unlocked after the door adjar light and front dome light flicker off and on. It is more prevalent when I turn to the left and almost stops and I turn right. It is only the front doors b/c the back dome light does not flicker on.
I've opened the side panels to see if any thing is chaffing however I cannot replicate when the truck is sitting still. I've jumped, pushed, jiggled doors, banged. nothing. I can only get this when There is significant bumps etc...
I am thinking that the wires that control the door ground when they are opened so if a wire is chaffed and grounding on the body than that could cause this issue.
I am going to pull the door switches off today and see if that solves it however I do not believe that they are the issue as they currently work great. I've jiggled them as well and they work as designed....
So here is my question:
  • Where is the main loom with the wires for the front doors
  • has anyone else had this problem and if yes how did they resolve?
  • Any idea on areas that might be prone to chafing?
Its really frustrating. Hoping someone else can help me find the issue.
Do you mean that your door lock would unlock also? If so, I've had this problem. Every time I would hit a bump, the door would unlock, door ajar light comes on and dome light comes on; also it would unlock when I made a hard left hand turn.
Turned out to be the switch that the front passenger door comes in contact with. The rubber cover was slightly off and I initially put a small piece of foam on the part the door contacts the switch to push it more firmly in when the door was shut. I eventually just unbolted the rubber cover and readjusted it and that fixed it without having to leave the foam piece on the door.
Check those switch contacts first.
Good luck,
Salue
I am having the same problem. will do. I think it has to do with.
More info: this morning I pulled both switches and unplugged them from the wiring harness. When unbolting the single bolt on the DS door the light flickered. just upon initial few turns. Drove around today and no flickering. I think its the contact wire running from the bolt and completing the circuit. I will pull the panel again and see if I can find where it might be loose.
My money is on the door switches. Mine did the same thing, swapped out the drivers door switch and it hasnt happened again.
The flickering when you removed it is normal, the bolt acts as the ground for the switch.
Good luck
Daisy
