blinker relay buzzing - anyone else's do this?
Today while coming off the freeway, I switched directly from right blinker to left blinker and the blinker relay gave off a buzz as left was engaged so I disengaged it instantly. Duplicated it about 10 seconds later but could not get it to do it again. Seems like someone once mentioned this but nothing came up on search for blinker.
When it was working, I noted that the volt gauge was moving on each blink. I think I've been pushing it with my battery. Maybe this is the first symptom that my voltage is threshold. I'll have to check the log, but I think it's 6 years old. It's time.
DougM
I think I have had the same issue for almost a month. I have not noticed the voltage fluctuation. I will observe the voltage next time it happens.
The buzzing is a sign of low voltage and is probably related to a poor ground somewhere.
The "old school" flashers like we have, work by passing the current through a bimetallic strip with the contact on the end. When the current goes through the strip it heats up, bending the strip and breaking contact, then it cools, recontacts, repeat. When less current flows they flash slower, with more current they flash faster, when they try to pass way to much current they buzz.
IIRC the flasher is before the switch on the Toyota system. Your switch maybe going bad, ether trying to flash all of the lights or shorting, causing a high current draw on the flasher.
