Bleeding brakes
Anaheim, CA
Next on my list is to replace the old crusty brake lines, pads, and flush the brake fluid. Due to major brake fade a few weeks ago coming down the mountain trail.
I have been reading up here on MUD as much as possible and watched a few videos to be prepared for the worst. I found the correct order for bleeding. I have a vacuum pump thingy. No clue if my LSPV even works. Ordered the Dorman brake hoses & powerstop pads from RockAuto.
Is there any tips when it comes to bleeding the brakes?
Brake fluid type DOT 3 only correct?
How much fluid should I buy if it takes 3-5 tries?
Three quarts of DOT3 ought to do it. Start at the wheel furthest from the engine, etc etc etc, I'd recommend going around several times.
Is it as bad as everyone makes it out to be?
I keep reading about how air gets trapped in the ABS
It's a two person job for sure, and like I said, go around all the wheels multiple times. I bled the crap out of my Lexus (which is basically the same system as the 100-series) and still have air in there somewhere...
No it's not bad at all. Bleed all the corners and LSPV. Drive the truck and find some speed bumps to hard stop over or a dirt shoulder. Get the ABS unit pulsing. Then bleed all 5 points again. Every single time there are more bubbles released. Toyota has an SST but its $$$$
What is an SST? I read that somewhere else
I used a pressure blender so a 1 man job but, I had to bleed and then go for a drive brake hard a few times to activate ABS then bled again.
DOT 4 brake fluid has a higher boiling point (less chance of brake fade), later fluids 4 and 5.1 are compatible, I have not used the 5.1 but 4 is fine IME.
Regards
Dave
Regards
Dave
Dave I have read that our FZJ80's aren't supposed to use DOT4. Is what I read incorrect?
There is nothing special about the 80 brake system. Brake fluid is backward compatible, in fact dot 3 is virtually non existent in Europe.
The base chemicals are the same with some enhancements to increase the boiling point, anyone who has had a problem with dot 4 already had an underlying problem.
I use it every day in customers cars old and new, I will post up if I get a dot 4 related problem, don't hold your breath.
Regards
Dave
I'm fairly sure it's DOT3 you want. Someone correct me if I'm wrong, but the Lexus takes DOT3 and so does the 100-series.
There is nothing special about the 80 brake system. Brake fluid is backward compatible, in fact it is virtually non existent in Europe.
Regards
Dave
Thanks again Dave. I feel much better now about using DOT4
Agreed that was the original spec but the 80 was designed around 1986, DOT 4 is in effect an upgrade.
Regards
Dave
I had zero drama bleeding the brakes on my '97. Nothing special about our trucks. I ran two quarts of DOT4 through and everything was coming out clear. I'm a firm believer that bleeding brakes requires only two tools: a 10mm line wrench and a second person. No more, no less. Don't over complicate things.
Bing. Go.
I was working on my brakes, and accidentally let the brake fluid drain completely from the system, when a hose clamp came loose near the rear left brake caliper, and I only noticed it several days later when I worked on it again.
I topped it up... and the brakes all worked fine?
Rather odd, the last car I had that had air in the brake system the brakes didn't work at all, the pedal went to the floor with no resistance.
I will bleed them anyway just to be sure, as I don't really want any air bubbles causing issues right when I don't need it.
Yes bleed them asap. This a dual circuit system, it is possible that one circuit is working properly and disguising the other circuit which may not be up to snuff.
Your experience with your previous car was either a single circuit system, or a dual system with a fault.
Regards
Dave
You most likely wont find DOT4 in the USA.
Use DOT 3. It's more available and matches what's already in there. Don't change something that doesn't need changing or a reason to introduce a new problem.
DOT 3.
