Blackstone Report = HG
Stuck between a rock and a hard place
Well, as the title notes, the time has come to take care of my HG. 156,000 miles. :crybaby: It was replaced in January 2003 at 97,000 miles by a local dealer, but appears to be gone once again.
Recently changed the oil and sent to Blackstone for their analysis. Figured that it was worth the $20 to confirm the suspicions of the PO that the HG was slowly but surely failing.
The rep from Blackstone actually called me, expecting to give bad news, and I was likely one of their easiest calls of the day. They noted that the amount of coolant in the oil was very small, but definitely there, and that there did not appear to be any damage so far to the bearings and other surfaces due to the low amounts of metals in the sample.
The truck would use maybe a cup of water every 1500 miles, which is not huge, but noticable. No bubbles in the catch tank. No performance or other issues noted. Temps run fine (have done the RT temp gauge mod), and all else looks normal. No codes, misfires, etc. Toyota Red, since new.
The good news is that I already have all of the HG replacement parts from CDan, as they came with the truck...including all hoses, belts, cap, rotor, silicone PHH, etc, etc. The only thing I can think of to add to the list would be ARP studs.
So, for those sitting on the fence "wondering" how your headgasket is doing, my advice is to get your Blackstone report so at least you will have the knowledge of whether or not your rig currently has any coolant getting into your oil.
So, the decisions now are:
1. When to do the gasket?
2. Do I do it myself or find a shop?
I have yet to do a few call-arounds, but feel that the local dealers will politely "decline" to do the work with owner-supplied parts (even though they are in OEM Toyota boxes with CDan stickers and the PO's name on them)...or that they would try and wiggle out of giving any guarantee of the work. Mudraks is a few hours away, and will definitely give them a call.
Definitely got the frown from the :princess: when I mentioned that I have changed HG's before on other vehicles...so that may drive me in the direction of a shop for #2 in the name of household peace. Any suggestions of shops in the SF Bay Area greatly appreciated.
Will definitely keep Mud posted on the whole process, and looking forward to a question-free HG.
:cheers:
Steve
I believe that MudRack has done a few up in the valley.
If this was done once before, check the block real carefully for low spots and warping if you do this job your self. the Tech may not have cleaned properly or did not look at the block well enough when he inspected the block. If the top of the block is bad, it will either need to be pulled and machined, rebuilt or a used engine(cheaper) or new short block(expense).
I see you have a supercharger on this. If this is the case, buy ARP studs when the job gets done. If you choose not to do studs, buy new head bolts as well.
You may also want to just pop the valve cover and look to see if the plugs in the Head are not weeping a bit(similar to Idaho Doug's problems with one head a couple of years back).
Good luck with this.
Do you need some measurements Rick?
If you need some help in this let me know. I should have a head off a truck monday night.
Why is the Supra not Ideal? It threads longer into the block than the stock bolts. It can go futher into the block than you want it to go if not careful(maybe not ideal). If you go to far, then you do not have enough thread for the nut. Just takes some thought.
It is nice that they are thinking of this now. When my buddy Kevin tried this a couple years back. They did show much interest in doing a kit for the 1FZ.
The studs from the Supra kit are not long enough. They don't completely pass through the nuts. ARP does have a stud from another application which is 10mm longer and should work perfectly. The measurement they need for the washer is the outside diameter of the factory washer and the spot face it sits into the head.
My head should be back from the shop soon and this is one of the first things I need to get to.
I did ask them about putting together a 1FZ-FE kit and they are reluctant because they have had issues when doing so in the past. So the cost will be more money because you are buying pieces.
yup, had the same thought as Robbie when reading the OP. Would this not be the first case of a new style OEM (I guess if done by a dealer) HG that failed? Unless poorly installed or some problem with the block/head, that seems unusual. And the amount of coolant lost is minimal. Makes one think it's not the HG itself but something else...
Such as the oil cooler.
Good luck...
PM sent !!!!
HG was done at a local dealer.
The owner (original) was a Service Writer at the dealership, and according to his compatriots whom I spoke with recently, he was very, very, very particular about the rig. The service history that they gave me (the dealer) was exceptionally detailed. Nothing was missed over the first 133k miles of it's life. I think a visit to the dealership where he now works may give a bit more information...though I think that the mods to the rig will give him a bit of a shock (it was stock other than the S/C when I bought it).
OK, so how to confirm or rule out the Oil Cooler? No signs of external leaks (other than the usual oil pan seepage...yeah another item to sort. Will be digging into the FSM this morning to see what it says. Will also pop off the valvecover to see if the plug holes show any weepage.
Visually the oil was clear at 5,000 miles, no discoloration or mocha latte. Just looked like normal 5k Mobile 1 usage.
As said, I have the headgasket kit from CDan, and will be doing my inventory to see what I have and what I may need.
Essentially I see this as an opportunity, instead of something bad. My mind starts to drift towards what "upgrades" can be done to the head, etc. while it is off...ARP, port, polish, Cometic gasket...
Rick, let me know how things go with ARP. I have also heard that the Supra kit can be too short. One post noted that a set for the Opel V6 works, with two extra studs left over. The engineer-mind in me says get the ARPs over re-using the OEM bolts (inherently stronger, and more accurate torque settings).
Gotta get off the couch now, and out into the garage for a bit of work.
:cheers:
Steve
In my other post, the threads you install in to the block are going farther than the stock bolt goes into the block. ARP does not recommend tightening these studs into the block. They want them loose. To me this means not bottoming them out. While I do agree they could be taller. They fit according to the instructions they provide. The installer needs to measure off the distance of the stud and not go any father when he installes them.
Oil cooler would be a tough one to diagnosis and a pain. You would need to pull it and have a custom set of plates made up and pressure test it. Cost on a new one is just under 500(a bunch of money.
Steve, to clarify what you're looking for, it's the large Allen headed round plugs atop the head visible with the valve cover off - not the spark plug holes. You won't be able to see the minute leak you describe if it's what happened to me without putting UV dye in the coolant and using the light/glasses that come with the kit. You'll also need to rent a cooling system pressurizer - nothing more than a bike pump that fits over the radiator neck. I'd consider doing this as I was - looking down each cylinder (the light is tiny and on a flexible neck for insertion into spark plug holes. If it's the classic HG failure (for some reason I don't think so) you'll see bright green drops going in the cylinder. If you don't see these and nothing appears atop your head from a crack then you've 99% ruled out the head and gasket which may save you a bunch of time and money. Then you'll be focusing elsewhere.
What I was going to do if my dye/pressure testing found nothing at this point was to drain the oil and leave the drain plug off and keep the coolant pressure tool on it until I got bright green coolant drops coming out. Then I'd know I had dyed coolant wherever the problem was internally (with oil cooler #1 at that point) and pull the oil cooler. If it was full of green coolant drops my search would have been done.
This may be a useful strategy for you, too especially since it seems highly likely the HG was correctly done recently which was exactly MY situation.
If you want to call me, PM me and let's swap numbers.
DougM
How much in parts to replace HG yourself???
I'm curious how much I'm looking at in parts from C-Dan, (Just a ballpark) to replace the HG and the other recommended stuff to do while there?
Don't mean to hijack the thread but others that haven't done this yet might be interested as well.
I do remember reading about the oil pump leak and was surprised to see what a mess this was in the guys rig. Guess that's something else to watch for.
Not sure why this would be the case.
There has been more than one instance where someone has seen the gaskets fail, which would let oil and coolant mix. There's also been a few cases where it has rusted through, which could allow it to mix.
Not sure why you'd need custom plates to pressure test it, if you pressure tested the cooling system via the standard radiator jobbie, you'd also pressure test the oil cooler.
If the oil cooler needs more than just gaskets (IE: rusted through), I would be getting one from a junk yard 1FZ. Otherwise the gaskets should be fairly cheap from Cdan.
The best way to "test" it (aside from the coolant system pressure test, or what Doug outlined) is really to pull it and see what's happening. If it's the failure point then it should be visible. If it's not, then all you are out is the cost of the gaskets and the time, not a huge expense. Not a bad idea to do it as PM either given the age of the vehicle.
I am definitely leaning towards pulling the Oil Cooler to see if there are any visible issues there; rust, etc. As Gabe noted, cost of a few hours time and a couple of gaskets. Need to pull my S/C which adds some time, but I need to empty and refill it with fresh S/C oil anyway. I would be pretty happy to find that the issue was as simple as a few leaky gaskets.
Would also do the dye-test / pressure test for the leaks into the cylinder/cylinder head plugs at the same time as Doug noted...minimally invasive, and should give a good indication of any visible (via UV) leaks.
Will be calling CDan for some parts on Tuesday, and also put in a call to Gary at Mudraks to see what his schedule looks like for the coming month(s), as he seems to be a busy man...just in case it really is the HG and I need to get on his calendar.
Off to Europe shortly, thus might not be able to dig into it until I am back in late March.
:cheers:
Steve
Well all is out of the truck and the diagnosis was called by Powder Pig (Robbie) early in the post. By chance he is actually the one doing the work, as there are five of us here in the SF Bay Area having HGs and a few other items sorted over the next two weeks.
There was a very small hairline crack next to one of the head plugs. Impossible to see without using the flourescent dye and pressurizing the system...and by small, we are talking pin-tip-sized drops at pressure every few minutes. More coolant was leaking from a few hose clamps, but no doubt that my head is toast. :frown:
A new bare head on order from CDan, and that will be here sometime late next week, as long as it makes the left turn at Albuquerque. In the meantime, we will be addressing the various and sundry oil leaks around the bottom side of the motor.
My place right now is Cruiser-land with my 80, and another LX450 in the carport awaiting top ends...and Robbie's 80 in the driveway. Glad to have one of the best Cruiser mechanics handling the whole ordeal, as the Toyota service department definitely :censor: it up in the past when they "serviced" the HG and likely missed this one. Looking forward to no more coolant issues, and getting back on the road and trail. :steer:
:cheers:
Steve
P.S. I won't get into details at this time regarding the local service shops work, but needless to say we were amazed by some of the odd things which had been done, and in some cases had not been done when they replaced the HG, and also had installed the S/C. Needless to say, we will be "fixing" some things which should have been done right in the first-place.
Today's news...some wear to the rod bearings, and best to replace them (and potentially the mains). Word to others, if your rig has any issues with coolant in the oil, take care of it early. At least the pan is off, and ready to be addressed.
:cheers:
Steve
