Back for some more help from the more experienced. I got a 1984 BJ60, first diesel and I've been learning and searching as much as I can but need some guidance on this one. My superglow has been running flawlessly up until recently it's been cold starting pretty hard. I haven't checked air leaks as of yet but I'm pretty confident air isn't an issue as I've eliminated a few this past winter, busbar gets 12V and knocks down to 5-6V afterglow as it should but also maintains a constant 5V after both relays cycle off
Correct me if I'm wrong, but once the super glow system times out there isn't supposed to be any voltage going to the busbar? Gut tells me one of the relays isn't closing properly but I'm hoping someone has dealt with this before and can point me down the right path. I know most peoples answer is the Wilson switch but I would like to keep this rig factory if possible. Timer works and I also picked up a second hand timer in good shape for a bargain so I'm kind of committed to keeping the system. This also started when i had some corrosion build up on the battery terminals - cleaned them up as well as all the relay connections and bus bar with no improvement.
Any input is greatly appreciated
