BJ42 Front Suspension Replacement
Niagara Region, Ontario
Hello Everyone! First post as a new member!
Recently purchased a BJ42 which needs some work here and there. First thing is replace the front suspension entirely. (There rear will be later, It's fine now) New leaf spring packs, u-bolts, shocks, shackles, bushings and bolts. The front leaf packs look to have been modified/hacked and I want to replace it all with new parts.
1. Where is a good place in Canada to source OME suspension parts/kits? I live in Niagara Region, Southern Ontario.
2. Running 33x10.5R15 and want to maintain same ride height or just slightly higher. I assume 1.5" or 2" lift will maintain similar ride height?
3. Every where I look for parts only references the FJ40. Is the suspension the same between the FJ and BJ 40 series? I assume that it is.
4. Is there much difference in weight between the I6 gasser and I4 coal burner? Should I worry about sag or heavy duty option leaf packs? I don't want to knock my teeth out when I go out for a ride either...
Any and all advice accepted. I'm a long time first gen pick-up and 4runner owner now converted to the LC world. ;)
