stevebradford
In the shop
Did you swap to a nine tooth starter gear?
It’s likely the starter gear is not engaging with the flywheel properly. the flywheel has a different tooth pattern between the non gear reduction early starter and the gear reduction middle also unavailable starter. The gear you need and info the make your new starter work be found in this thread.
forum.ih8mud.com
(a gear (9 tooth) has to also be swapped over when you have a non gear reduction starters
b and 3b starters and flywheels
forum.ih8mud.com
