For Sale BJ40 ARB Bumper, 4 Wheel Disc, etc.
BJ40 ARB Bumper, 4 Wheel Disc, etc. SOLD
SOLD/Traded 3/9/2010
F
FOR SALE
1980 BJ40 TOYOTA LANDCRUISER
B DEISEL ENGINE Replaced B with 3B on 2/20/2010
4 SPEED TRANSMISSION, 4X4
$18,000 Reduced $16,000 Make an offer
I am not excited about this sale but for financial reasons I need to sell it. I purchased this truck as a project for the purpose of using it as a daily driver and trail rig. It is not perfect as it some flaws but it would make a great daily driver or trail rig as were my intentions.
I have invested approximately $35,000 into the truck and would like to get $18,000 for it and the additional parts that I have but not installed. I am happy to answer any questions you have, just ask. I will also Consider Offers, I may consider partial trades for an FZJ80, but financially I cannot trade straight up. I have additional pictures if you want to see something specific just ask, and I will get it for you(send me your e-mail). I will try to describe it the best I can but I am will probably miss something, so please ask questions.
The Good
The following is the work done and new parts replaced on the truck since June of 2008.
New Tie rod Ends (5)
New Custom Aluminum Radiator W/Electric Fan and Electronically Controlled Thermostat
New Water Pump and Gaskets
New coolant hoses
New Thermostat
New Thermostat Housing
Engine Block Heater
New 4 Wheel Disc Brakes
New Brake Master Cylinder
Custom Bucket Seats with New Locking Tuffy Security Center Console
Custom made seat bracket
Rebuilt Alternator
New Battery
Replaced Voltage Regulator
Rebuilt Starter
New Glow Plugs
New Complete 2inch Exhaust System
Pro Comp ES3000 Shocks (4)
Steering Stabilizer
Front Axle Rebuilt: Steering Knuckles, Wheel Bearings, Poly Body Mounts
New 2.5" Lift Shackles W/ Poly Bushings
New U-bolts: Front and Rear
New Front and Rear Hard Brake Lines
New Water Pump
New Aluminum Diff. Cover
New ARB Front Bumper
New Warn M8274-50 8,000 pound winch and cover
New Door Panels
33X12.50 Maxxis Tires 15X8 Weld Wheels
New Windshield Wipers,
The Steering Column was freshened up
New Spray in liner in Tub
Family Roll Cage with 4 point frame Tie in installed by Proffitts Cruisers
Rear bumper with tire carrier and high lift jack mount built and installed by Proffitts Cruisers
New Custom made Sail Cloth soft top by Best Top with 2 piece soft doors.
2.5” MAF Spring Lift
4 Point Seat Belts
Powder Coated Parts:
Seat Bracket, Valve Cover, Alternator and Water Pump Pulleys, Clutch, Brake, and Gas Pedal, Arms and Assembly, Thermostat Housing.
The Flaws/Needs
It could use a paint job, it has some cracking and bubbling. It had a two tone paint job two different greens inside and out. I lined the Tub so it took care of most of the inside.
The Tub is not perfect it has had some patching done on the floor in the front and in the back. There is some fabrication done to the wheel wells in the rear, Who knows? The truck was imported out of Costa Rica by the person I purchased it from. The welding repairs and fab work were done there. That said the tub is very solid and I planned on using as long as I could, considering I planned to use it for what it was.
Both fenders in my opinion should be replaced, I have two good fenders off of a 1972 that are in great shape I intended to use them myself, they come with it.
The Turn Signals did not work when I got the truck, I have replaced some of the wiring and had them working for short periods of time but keep blowing the flasher fuse. A simple fix I am sure. I did not like the factory turn signals so I had the turn signals mounted in the bumper in the front and intended to keep the fenders smooth.
UPDATE 12/29/09 I fixed the Turn Signals. I replaced some of the wiring to the tail lights and cleaned and rewraped the whole harnnes to the rear lights, checked the grounds, and replaced the flasher fuse. So it is all in good working order.
The 4 wheel drive does not seem engage at the front axles, I have never had it wheeling so not real sure. I did not bother with it yet as I planned to replace the transmission and transfer case with an H55F set up I purchased.
UPDATE 12/29/09 I am looking into the 4 wheel drive. So far I have found that the the transfer case is engaging and turning the drive shaft to the front axle. When driving I can feel that the gearing is different between 4 high and 4 low, I feel confident the T.Case is engaging correctly. I pulled one of the front hubs off and could see that it appears to be packed full of grease which may not be allowing it to engage. I am going to go through a few tests here in the next few days to try and determin if the hubs are the problem. What I suspect is that the hubs will need to be cleaned and rebuilt or replaced and the front 4x4 should engage. The rear turns engages no problems.
2/1/2010 Replaced aftermarket hubs with Aisin hubs. 4wheel drive works.
I just put MAF 2.5 inch spring lift on it but it sits a little low in the front, I intended to install a Shackle Reversal to even it, I believe this would lift the front closer to level.
The wiper motor just quit. I have not even looked at it yet.
UPDATE 12/29/09 I fixed the Windshield Wipers, the motor was fine. I cleaned all the fuse contacts in the the fuse box, replaced a few questionable fuses. Cleaned the plugs on the Wiper Switch and Wiper Motor. Also replaced some of the old bolts with new. working good now
Does not have a heater or AC, but I have an New Vintage Air heater for it just not installed.
Parts Included but Not Installed
H55F Transmission and Transfer Case Used, Comes with rebuild kits for both Trans. and T. Case. To complete the install it comes with: New Clutch, Bearing Retainer, Fine Spline Hand Break Drum and Special machined nut to attach it, and Rear Transmission Mount.
Factory Power Steering Set up: (3B Power Steering Pump and Bracket, Harmonic Balancer (double pulley), Tensioner Pulley and Bracket, and Factory Power Steering Box, “just needs lines”. I purchased most of these parts from 4Wheel Auto In Canada, they said this set up should work on a B Diesel.
Turbo Manifold and Rebuilt Nissan Turbo
Font bib, Hood, Fenders, off of a 1972
Full hard top with new Seal needs work paint and assembly
Ambulance Doors and Front Hard Doors.
I am not interested in selling any of these parts separate at this time. In the event I do not sell the Landcruiser I would like to keep the parts for my own build.
OR
It is located in Northern New Mexico, near Santa Fe
Pictures
Added Pictures
Pictures
More Pictures
There is a lot of useful information in your post, so maybe I missed this, but is it registered and tagged?
Pictures
More Pictures
The vehicle is tagged and registered in New Mexico. I purchased it out of California where the previous owner had it registered and tagged in 2007.
Rear Disc Brake Conversion, I have replaced the the rusty exhaust in the picture.
Still for Sale. I am open to offers?? So I have posted what I have into it but I will sell it for a fair price. If anyone cares to share with me what they think is fair I would appreciate he feed back. Send me a PM.
Price reduction $16,000 OBO.
Just wanted to give an update, I was able to fix the Turn Signals and the Windshield Wipers. I cleaned all the fuse contacts in the the fuse box, replaced a few questionable fuses. Cleaned the plugs on the Wiper Switch and Wiper Motor. Also replaced some of the old bolts with new.
The turn signals I replaced some of the wiring to the tail lights and cleaned and rewraped the whole harnnes to the rear lights, checked the grounds, and replaced the flasher fuse. So it is all in good working order.
I am looking into the 4 wheel drive. So far I have found that the the transfer case is engaging and turning the drive shaft to the front axle. When driving I can feel that the gearing is different between 4 high and 4 low, I feel confident the T.Case is engaging correctly. I pulled one of the front hubs off and could see that it appears to be packed full of grease which may not be allowing it to engage. I am going to go through a few tests here in the next few days to try and determin if the hubs are the problem. What I suspect is that the hubs will need to be cleaned and rebuilt or replaced and the front 4x4 should engage. The rear turns engages no problems. If anyone out there has any suggestions or previous experience with this issue please send me a PM, I will take all the help I can get. I have read a few threads on rebuilding the hubs, probably my next step.
Sold / traded 3/9/2010
