BJ 40 Steering Linkage
Sri Lanka
I have finished the Knuckle restoration .
Now in the process of installing TREs & Steering Linkage & noted a little play at the end of the Rod below the Pittman Arm. There is a unit secured by a Cotter Pin under Pittman Arm . Is there an adjustment inside to reduce that play ?
Is there a repair kit available for this unit ?
Thank you in advance
Are you saying there is play after tightening the clamps or prior to tightening the clamps? If it is prior to tightening then tighten the clamps and see if the play is still present.
