Bit of wiring..hazard issue
Chatham NJ
Well after finally tackling the gauge pad..i decided to replace with the $OR i had laying around since the winter. Well after hooking it all up when i tested the hazard pull the high beam indicator started flashing instead of the proper ones. Ripped it all out..plugged an OEM one in before everything else up. same damn thing. That is when a tornado came into my truck and it got torn apart.. Looking for a OEM wiring diagram an possible ideas on what to check..i figuring grounds but NOTHING changed all working perfectly until the gauges got removed..Thanks! stay chilly..
As of right now I’ve figured it out..the SOR pad comes with a wire no mention of it installing anywhere unless I’m completely blind..that connects to the hazard cluster. The OEM dash is metal and grounded with it being mounted. All lights functioned properly..wasted my time all I had to do was ground the blinker/highbeam cluster. Finish tomorrow
