Birfields?
Yacolt, WA
Birfields UPDATED***?
Thank you for all who have helped so far.
Here is where I am at now. I am 3/4 of the way done with my front axle service but I need a new or used Birf for my DS.
Question best place to get a new or used Birf?
If I go used I am told only 91 and 92 will work. Correct?
Can you just replace the Race and bearings only?
I need to get something ordered for tomorrow delivery otherwise my In Laws will drive from CA and stay at my house for a week:crybaby:.
Trust me I will be:crybaby:
Whoops; forgot to mention Downey Off-Road (or any other advertiser) they have been around a long time and make great stuff. Was just writing fast.
g
New Question Birfields?
Hi Guys,
Needless to say I will not be spending Thanksgiving in Northern California with my wifes family:crybaby:. I ordered a part to arrive today and it was the wrong part. A Birfield that was about 1" in diameter smaller than what I need.
Questions: I think I have learned from this site that 91 and 92 birfields are different from 93 to 97. I was told that 93-97 have a longer spline and you would need to change the drive flange if you wanted to use on a 91-92?
My supplier is showing them as universal 91-97 as well as other years. There is no mention of needing a new drive flange.
Is the above true?
Anybody else with a EMPI Birfield? Part #?
Should my supplier know this stuff if they are selling it?
At this point I want to work with my supplier to get me the right part. I am not real happy at the moment with them but we see how they take care of a customer who is in a rush and pays to have something overnighted? So far I am not impressed.
HEFE
Hi Guys,
Is the above true?
HEFE
1991 through mid 1994 has a shorter spline length on the drive flange area, and has a shorter accompanying drive flange than the later 1994 through 1997 birfields. The probable reason that your supplier is selling only one style is that the later longer splines are more robust; therefore there is no reason to install the obsolete design when making a replacement. If you install a later-model birfield it will require a new drive flange to match.
AFAIK, the bell diameter is unchanged through the years.
New question
Thanks psfpilot!
The new outer Birf I purchased is made by EMPI. Part # 49314.
I am told by my supplier that this is the correct part. But the Outer Diameter is almost a inch in diameter smaller:mad:?
Anyone know anything about these or correct part #?
Thanks in advance,
HEFE
HEFE;
You got to call/send a pm to either CruiserDan (American Toyota) or Christo (Slee Off-Road) to make sure your parts are the correct parts; something is obviously wrong if what they sent you is one inch smaller than the OEM part? Is that what you are saying, the bell (fat part) is one inch narrower in diameter?? Where was it made? Please don't say Taiwan or China.
Man-A-Fre also carries the correct parts, you can go to their website and check it out; don't know if they have Saturday hours. They sell a Japanese made Birf that apparently is OK quality but is relatively inexpensive; but for all the work involved and piece of mind, I figure, go with OEM at least.
I have not done mine yet, but these guys know what fits and what doesn't.
I recently asked for myself on the forum what parts to go with for a replacement; the response I got was OEM (Toyota) as I run only slighty larger than stock tires and do no aggressive off-roading. You can get OEM birfs (and all the other parts) at a discount from CruiserDan who works in the parts department at American Toyota.
Birfield
If it is about 1 inch smaller than an 80 Birfield then I would venture to suggest that they have supplied you a Birfield for a 60 series cruiser instead. As they were part time their Birfields were smaller.
Work with them to get it sorted and consider it a worthwile exercise educating them as to the variations in Landcruiser models. Get the upgraded Birfield with the Longer splines for the druve flange and replace the drive flange as well, It will get rid of some of the free play in the drive train at the same time.
Cheers
Hmm.. if I were going to all the trouble to change out the Birfields, I'd get a set of stronger, Longfields. Just my opinion. Good luck!
