BirFields, OEM - Newfileds - Longfileds
Puerto Rico
Hi,
I'm a new member so please bare with me...
I've been looking up all threads refering to FZJ80 and brifs and I'm trying to come to a conclusion on what would be a good Birf and also to save some cash... note: savig cash is not a priority...
Most of the threads I've found are a few years old and are of great informational vaule, not so much as to were to purchase and basically how much..
Which of these Birfs, OEM, NEWFIELD, LONGFIELD are considered by you to be in your best interest? Where could I find one? and Basically a rough estimete on its cost...
And do they come with a ABS RING and if not how do I install the ring?
I'm in the process of arranging a 4-5" OME Lift , I would like to get the largest tire for that hieght (which I have no idea what that mey be right now), an will be using this truck as a low milage daily... ( I dont get out much) 3-5k miles a year. I have 94K miles on this LC and the engine is out right now in the process of changing ALL seals, gaskets and hoses...
I found most of the parts from reading here on complete Knuckle rebuild kits, and bearings... but I've read that Lonfield is no longer salleing direct, and some have had issues with the Newfileds... and I would really like to not need to install the ABS RING if possible (pre-installed), since I'm in Puerto Rico and I really dont trust many mechanics around here... Except for 1... that lets me watch...:clap: but I'm sure I can find a way of installing the ring if it came to it.... and you guys shine some light on the procedure...
I would love to get all the parts including Birfs as a KIT from one single supplier if possible, that is willing to ship to PR (U.S. territory so it's Domestic)
Any related info very much welcomed...
We can't answer questions here until you post a picture of your truck.
:p OK... It's pretty much STOCK... changes are on the works now... It been out of commision since febuary... I've had for about 5 years without using it much, Coolant fluids were not maintained and I'm paying the consequences now... Blown HG...
As I stated... I'm in the process of research to "Pimp my ride" for improved off-road abilities.;)
After a bath.... a few years back... looks the same now...
Here's the removed engine... Cyl #6 gasket problems....
Seems I've encountered most of the FZJ80 common problems... I'm not the original owner, and only now I'm I understanding the PM needs of this truck... of course I'm setting a good baseline first and that's part of the need of this thread..
The truck is at the shop so I don't have the year/month of the build to actually see what version of the Birfs I should have... will get that info soon... (would I get that from the VIN or door)
Thanks in advanced
Swapping the rings is easy. Tap them off with a hammer and brass drift. Tap them back on to the new birfs.
Why do you need new birfs on a truck with low mileage?
Sorry for the delay in response... for some reason my IE8 doesn't like this site today:hhmm:
Anyways... heres some background info, (previous post: IH8MUD.com - View Single Post - Should I buy an 80, costs of ownership?)
A few years back I noticed my truck leaking fluid from my front driver side wheel... I soon realized that my differential seal was allowing fluid into my knuckle.... I dont know how long this was going on since I'm not the original owner. I replaced the seal myself and kinda repacked the Birf (half arsed). On top of this my Wiper Seal on the same tire is really bad now too... leaking grease not soup... all over... so I imagine I ran the Birf dry for a while..
The wheel now makes a slight clicking sound when wheel turned an usually on uphill turn (to the right)...
The previous owner just did routine oil changes, so everything fell on me for maintenance..
I really could have used the info on this forum a few years back...:doh:
Thanks to a member of a bike forum I frequent, he lead me here:cheers:
Now I understand the PM needs of this truck and will take much better care of it, but I imagine that the 30K bearing maintenance and the 60K Dif maintenance were skipped, and on top of this the heat here in PR really dried up all seals and hoses on my LC... Most were almost like plastic/brittle. So when I blew the HG (rear #6 Cyl area was getting water) I decided to remove engine and overhaul all seal and gaskets.
Mind you... I only drive about 3-4K miles a year or so... so I sits in my garage most of the week.
So now Im inclined to buff it up to a higher Off-road capable... and worried about the Birf clicking... since I have to basically rebuild the entire knuckle to replace the wiper... I might as well replace this birf... I read up on the swap... but some have stated that the clicking is just gona come back again sooner or later. I might as well replace them and take better care of them so they will last me. I'm thinking of 35" or 37" tires...so I want something that will hold up to them....
Who knows maybe the Birf Is just Dry and a repack might solve this, but I wont know until I open it up.
My next set of questions might be how much lift do I need for a 35" or 37" or if they will even fit with my stock fender flares... but I'm searching FAQ first for that...
There's a lot of good information here and I'm reading as fast as I can... :p
MODS to come would be in this order I think:
1. CDL Switch
2. ARB front bumper (light + accessories)
3. OME Lift kit (thinking of 4" front, 3" rear , or 5"F - 4"R but still reading up on this)
4. Tires... (depending on the lift, I really would like a big and wide tire the maximum my lift would get me)
5. Rear Bumper with spare tire
Of course a good baseline is what I'm trying to establish first.
I might not take it to the mud as much as I would like but I'd like to know I can.
OK, Stock....
Care to elaborate... just for my own OCD:)
Newfields are cheaper ( I think), so I guess this descition is made based on quality? and LongFields being maybe overkill for my needs?
Thanks...
I don't know anything about Newfields, but I do know that Longfields are not to be used in a full time 4wd truck. You'd only get about 15k miles out of them at least. (I read this on a thread here somewhere)
Go with stock. Don't try to get anything that's "cheaper" because in the long run you'll only end up screwing yourself.
My $0.02.
Your light duty OEM replacements will be fine, and will be cheaper than your chromemoly birfs. They will be harder, will wear better for daily street use but will not be able to take as much of a shock load that the Long or Newf chromemoly axles will take. The chromemoly should not be used in a full-time 4wd truck that you use as a daily driver, they will wear out.
I think Slee or IPOR sells an OEM style Newfield birf with the ABS exciter ring that will suit you well, and they are about $100 less than the chromemoly birfs IIRC:meh:
Thanks much guys!
Im needing new ones also having destroying a birf. It seems unless you can find a decent used Toyota one it's best to bite the cost and go back with Toyota.
The Slee's (cheaper ones) have a good price but the offroad durability may not be great. The Longfields are great offroad but if daily driven are only good for about a year. Seems the Newfields are like the Slee's. A decent price to get back on the road but may not hold long term offroad.
The Toyota OEM parts are proven to last years and years with on and offroad use. Im looking hard at just coughing up the money for the Toyota parts unless I can find a good used set. Figure the extra costs will be savings long term due to the OEMs lasting for years and 100k+ miles.
Find someone dumping their 80 for C4C and swap them ;) lol. You wrench, they get their new car loan. Everyone's happy :D
I think he's in Porto Rico, I don't think they are doing cash for clunkers there :doh:
Even though PR is an U.S. Territory and most Federal laws apply... I don't think this bill made it this far...
But we do have a "Clunker for Cash" market:D
Just got my LC back from a complete Engine rebuild... (finally all work finished xsing fingers)
Now I need (rush) to do a Knuckle rebuild. I PM Cdan but have not yet received an answer...
Before I purchase this kit I would like to ask, If I should just go ahead and call cDAN (what's the number).. or does anyone know where I can order this kit from that has good parts including the clip for the birfs.
I'm assuming cDan uses original parts?
I really need all parts excluding the Birf, but I would like cDan to quote me on stock birfs so I can weigh my options and I might as well replace the bearings? (94k miles)
My wipers are leaking like crazy one looks a little soupy from outside.
Thanks for any help... I need this done ASAP!
Cdan likes to get calls for orders. He is at American Toyota, 1-800-432-6668, New Toyota and Used Car Dealers in Albuquerque, NM | American Toyota
Another great source is Kurt at Cruiseroutfitters, (801)518-3937, Cruiser Outfitters
I have no financial interests in these guys, but they are great, dependable, and quick. Tell 'em the parts you need and they'll help you get the correct ones.
X2 on OEM. There is a thread on here about Longfields and daily usage. Not what I'd like to go thru. Stick to OEM.
Ordered the entire Font axle Knuckle rebuild kit from cDan.
Execpt for the Birfs for the moment, I'm hoping that the clicking was from dry birfs. I have not heard them click sence I got the LC back.
Will inspect them once I get them out.
For you to think about it.
It is nice to have used parts on hand. You can do that by not driving expensive parts to the point of destruction.
My birfs were clicking. a year and a half ago I had the whole front serviced. Did not buy the birfs but flipped them left to right. It was better for maybe a month. I had to do the whole thing again to replace the birfs.
My recommendation is this: buy the birfs now! do the whole job with replacing the birfs. Keep your still usable birfs as spares. Once you destroy you birfs (soon) they will not even be good as spares.
I also replaced the axles. they were groved slightly. But now I have decent axles and birfs to bring me home (or somone else) in case I break something.
Good point,
What I was planning on doing is removing the Birfs and inspecting them visually for wear and if wear is found, I would stop the build and order the birfs overnight.
My reasoning is that one of the birfs might be dry and it might be making the click because of that (even though I havent heard it again). If I find that's not the case I would order up.
Trying to maximize my budget.:o
But good idea on the need of spares.
I need to go out today and stock up on some tools to make this job go smoothly. (54mm socket, snap ring pliers, torque wrench)
