Birfield separated from inner axle
Montrose, CO
This is my first foray into the world of closed knuckle axles so I'm a bit green, but i know this isn't right. Story time, I'm pulling thirds for a regear and yesterday I tackled the front driver side knuckle with no issues. Today while I'm doing the passenger side I come to the point where I'm pulling the shaft out and was mighty surprised when the birf came out while the inner axle stayed.
This side has been rebuilt in the past according to the previous owner and timken bearings I found.
I found no evidence of a broken snap ring in the knuckle, and also didn't see any signs of damage. I'm going to order a snap ring and replace it, but was wondering if there was any reason it wouldn't have been done.
What does the diff end of the axle shaft look like? There is a somewhat common mod done called the Martack or Mar-Tac where a small weld is made on the splines to limit the axle from going to far into the diff. With that done there is no need for the snap ring. The advantage is that the birf can be disassembled for easier field repair.
Just re checked and there are no welds on the splines, I might be doing that myself tho.
