Birfield "remote" help needed...
Milwaukee, WI and Louisville, KY
Hi All.
Tomorrow I am tackling my first birfield overhaul job. My local mechanic (who has never done one, but is a good wrench and has all the tools) is going to help me through it. A team project so to speak.
I am wondering if there is anyone out there that has done a few (or more) that would be willing to provide some phone support in case we get stuck. I will have my lap top there and plan on following the instructions on here, but just in case would like someone knowledgeable that I could get in touch with. Will be doing it tomorrow during the day.
Thanks!
Justin
Agree - real time help excellent here.
I can vouch for the real time help...the peeps on this forum are great...helped me when I was doing mine.
Being a new'b here myself, there's a couple of things I learned on mine that may be of help to you.
I picked up a Power Built Seal Installer kit from Checker Auto for about $16. They have a variety of sizes that came in handy when I was replacing the races in the hubs and the oil seals in the inner knuckles. I lot of guys here have fabricated their own, but I didn't have any steel fab tools to make them. On the writeup in the FAQ, one pic shows a round piece of metal that was bolted onto the end of a brass drift..I felt that you need a smaler size (the same as the seal) for that inner seal so it seats all the way into the inner knuckle.
Use the old races to hammer in the new ones in the hubs. I used a hand grinder with a thin metal grinding wheel (about an 1/8th in. wide) to cut through two of the old ones (two different sizes). This makes them flex and shrink so they come out easier when you use them to hammer in the new ones. Got this tip from CDan (cstamm81, beno, bear80) ...thanks!!!. Worked like a champ!
Some recommend that you engage your e-lockers before pulling the axles...I didn't do this (because I didn't read about it before I did it:doh:) and mine went back in with no problem, I may have lucked out...I can't hurt to do it though. Definitely want to do it on the rear axle when you service it from what I've read.
I drove my self nuts looking for the spindle bushings (god I hate the learning curve that comes with being a new'b) in the rebuild kit that was talked about in the FAQ...
"Place a new Gasket in the position on the knuckle along with the bushing on the end of the axle and install the spindle."
This confused the hell out of me and they are shown on the exploded as a separate piece...they are brass (I think) bushings already pressed into the spindles and they do not come in the rebuid kit. You'll want to check them for excessive wear though...I've read on some posts that on some rigs they have fallen out when taking the spindle off.
When I took mine apart, there appeared to be a gasket that went between the spindle and the dust cover which isn't shown in the exploded drawing. I purchased a second spindle gasket to go on the outside of the spindle, between the spindle and the dustcover, just for good measure.
The amount of grease used in the knuckle and housing was a mystery to me...the pics in the FAQ are a little deceiving. I managed to get 2 1/2 14 OZ tubes of Valvoline Molysynth in mine but I'm wondering if it was slightly too much. So far I've put about 400 miles on it and I'm not seeing anything oozing out of the seals on the backside of the inner knuckle housing, so I think it's ok...although, I had to take the drivers side apart to re-torque the adjusting nut becuase that side came loose a little after the first shakedown trip. There was some MolySynth that oozed into that outer part of the hub but it hadn't worked into the hub past the outer bearing yet. In one of the pictures in the FAQ writeup, it looks like they prepared with two 14OZ tubes per side. The FSM says 2/3rds full...kind of hard to gauge. I would say 2 tubes per side minimum. But that's only my opinion. The concensus for the bearings seems to be good old fashioned hi temp Moly Grease like Pennzoil Red which is what I used...found at Wal Mart.
Hope this helps...good luck...it's messy! LOTS of paper towels. Nitrile gloves...if not...you might know this tip...use hand cream first, helps the grease come off a lot easier.
Hi All.
Thanks!
Justin
Post up and we'll help you out the best we can...that said, I've utilized the MUD phone tree before and have taken calls as well. So, if worse comes to worst, there is that option as well.
Good luck and, most of all, have fun with your rig.
-onur
