Birfield or spindle bushing?
good day fellow cruiserheads,
i have an hdj81 with fr/rr factory lockers, i noticed that every time i drive in reverse with the steering wheel turned left/ right i hear a clunking sound, then when i drive straight on a gravel/ rough road i also hear a clunking sound coming on the front axle. i had just repacked the front axle, changed all bearings, oil seals, knuckle bearings/seals repacked the birfs. i had checked on the brake calipers and its in good condition.
Raise the vehicle and check your front wheels for any slop without taking them off. Sometimes it's difficult to get a good preload on the bearings when you have too much grease in the hub. Also I would check your knuckle studs, lot's of people here have replaced them when they do a birf job. The studs sometimes back off on their own or snap. did you lube up the spindle also?
-Juan
I had the same clunkin sound and it was the broze spindle bushing. It had hardly any grease at all. I greased it and problem solved. If you don't want to take it all apart again, I think you can take the 2 bolts off the top next to the ABS sensor and add grease in that way and it will slowely get into the bushing. Not 100% about that though. I'd send Idahodoug a message. He had all the answers to my questions.
Steven
Sorry my last post didn't make much sense. Here is a picture I found in the faq. I think this is where you need to add the grease but I'm sure someone else knows much more than me on this. The bolt screwed back in the hole is for the ABS. dirsegard it and take the 2 bolts out and use a screw driver to pry out.
here is a link to the faq
https://forum.ih8mud.com/80-series-tech/78276-front-axle-rebuild-faq.html
attachment.php
The clunk sounds like the axle shaft bouncing inside the bronze bushing which I have come to accept is simply part of the 80's personality. Definitely best to add some grease to the square plug above to help encourage more grease out into this bearing which is in the spindle itself. If you JUST rebuilt the front axle and you KNOW you remembered to thoroughly pack that bronze spindle then don't sweat it - it may simply be that you're hearing something your truck has always done. Even right after a correct repack I've felt/heard this when the right frequency bump comes along. That frequency can depend on your tire type and inflation pressure as well as these variables simply change the frequency at which the tire/wheel will give the axle that little 'flip' that makes the axle rebound just right inside of the spindle. Does your diesel have the newer style roller bearing inside the spindle? You'd definitely remember it versus the normal simple brass bushing most show pictures of. If someone else repacked the axle, of course you have absolutely no idea what's going on inside now - done correctly/not done correctly, etc.
DougM
thanks guys for your replies, i have just disassembled the front axle and noticed that the spindle bushing has been worn out and the axle has 'some' play within the spindle bushing... i brought it to a nearby machine shop and had it re built with a tiger bronze. now it fits snugly with the bushing, not too tight, not to loose .. just feels right. I also happen to dismantle the birfield and had the ball bearings and the 'star' inter changed each side, and changed the transfercase from fulltime to a part time together with the propellers, and walla!!!! the clunk was gone, and with much smoother driving feel and better fuel economy...
WOW!
Good job.
:cheers:
Hdj81v: Did your shop rebuild the old bushings or machine new ones from a block of bronze and what is "tiger" bronze??
Man, you've been busy. Fast work.
DougM
hdj81v: did the machine shop make exact copies of the old bushings with the wiping grooves? Apparently those grooves are meant to channel grease from the knuckle housing into the bushing. The first photo shows the new style spindle bearings and mini-bushing and the second shows 25 pumps from a manual grease gun via the inspection port; some of the grease looks like it will fall down where it can then be pulled into the bushing?? I packed those bearings and where the bushing butts up to the birfield very well before I attached the spindle.
