Pulled my front end apart due to a leaky inner axle seal and a GRRR/vibration when I let my foot off the gas.
The birfield xtub shaft was contacting the spindle. THere are grooves worn in the stub shaft and the bushing is obviously worn down. I only noticed it because I swapped out my mud terrains for some road tires and had the windows up due to rain. Otherwise I never would have heard it. No idea how long it's been going on, but the bushing has been worn to the point that there are no grooves visible.
Question is how is this happening?
Bent housing?
The bushing definitely wasn't dry. The inner axle seal had been leaking for a while so I was keeping a steady supply of Moly pumped in the knuckle. Maybe the gear oil washed away the "cushion" of grease that the shaft would spin in inside the bushing? Or the grease was just too thin from oil dilution?
Everything was tight when I took the front end apart. Maybe a bad trunion bearing allowing the knuckle to sag a little?
Bent housing?
