"Birfield" Breakage.
Seattle, USA
Hi All:
So, which end of the front axle on on 40/45/55 Series is more likely to break a Birfield joint (when the axle is "locked") - the "short" side or the "long" (no pun intended! :D ) side?
Any opinions or comments as to why that particular side is more breakage prone?
Thanks!
Alan
In the rear, the short side has the reputation as the one most likely to break. That was the case when mine broke, but who knows.
With birfs, my guess they break pretty equally, but that's just a guess. I helped fix one this weekend that had blown in spectacular fashion, with shrapnel all through the knuckle. It took out the oil seal, mangled the end of the axle, and there was so much junk inside the knuckle we had to dig out the lower bearing and replace that too. I had to use a small angle grinder to resolve all the burs inside the housing. THe bell was in pieces, the inner cage was in many pieces and the balls had lodged in a way that prevented the knuckle from steering more than a few degrees. It was on the short side, though....
I have read the short side. Locked and backing up, wheels cranked. Just read, not done.:D
Ed
at the time of conflict... the one with the most resistance...
I bet if you had data from all the birfs that broke it would be almost even...except a slight amount towards the short side. I'm gonna guess that the long side has a bit more twist flex due to its length and the short side has alot less "give" so it will snap first 51 times out a 100. Of course this is not based on anything except my guess and is completely heresay in a court of law;p
I've broken two short-side Longfields.
One was from the first front axle "kits" Bobby sold. He later told me they were not worth a damn, and that he would heat treat a stock birf of mine for free as a replacement.
I broke that replacement yesterday. :rolleyes:
X2
Strictly from memory, it seems like more short-side birfs fail - which I would attribute to either the "extra torsion flex" theory, or the "can't see what's over there" theory - you pick.
When I pulled my ball-n-claw axle apart to upgrade to disks and 30-spline inners, my 10-spline short side had about a 20 degree twist right in the splines while the long side was fine. They were both fine a few months earlier when I installed the lockright. :D
