I have a 97 with factory lockers, can I use the axles from a 94 non locker? I can get the 94 as a parts truck since my 97wont pass emissions I thought Id pull the 94 motor and change it but that still leaves me with bad birfs on the 97 the 97 throws the 404code and so I thought changing the motor would be the easiest way to go? any thoughts?
I dont know about locker vs non-locker axle differences but 94 may not have the ABS so that would need to be pressed on. Then you would need to use the axle flanges from the donor as well since there is a 5-6mm length difference.
No. Well, yes and no. You can use the birfields but not the inner axles. The birfields may have the shorter outer shaft, as some of the 94s did, which would mean different drive plates but could still be used.
The inner axles differ, because the locker inner shafts have a much longer splined section.
That's not a smart motor swap either. An older motor in a new truck is an automatic smog fail in California. Don't know about Utah. Not to mention the controls differ enough that it will be a huge pain.
Changing a motor to fix a code seems like a rookie move. I don't remember what a 404 code is maybe EGR??? Just fix that. It will be trivial compared to a motor swap.
Well yes it does however in my own defense I can get the whole 94 for a couple hundred more than the birfs that need to changed on my 97 so I was exploring my options, I have changed the egr,vsv, and a bunch of other stuff and am now to the point of pulling a bunch of stuff to clean it out, been a couple of years since I read the procedure. At any rate I think Ill just fix the birfields and punt on the emissions.
Thanks for all your replies
94 engine won't have the reluctor ring for the crank angle sensor nor the spot in the upper oil pan to mount the sensor itself. Much easier to put a 97 block into a 94.
The bit about the axle shafts being different on locked/non-locked only applies to the rear. You can technically pull the birfs out of the 94 and throw them into the 97.. but that requires tearing down two axles. You'd probably be better off just tearing down the 97 axle and rebuilding.. and swap sides on the birfs.
