Take them apart and inspect like I mentioned. Do they both click? If so, I would replace them both. If you don't want to replace them, take them apart, clean them very well, and swap them. That's your best bet without replacing them.
Yeah, I'll drive for awhile when I get back and if it still clicks I'll need to take it sorry again. It's my dd so I'll have to plan it. Thanks for the advice.
Also while in there did you strip out and clean the steering 'stop' bolts, seen these wound in tight afterwards and in essence asks the birf to work at some abusive angles whilst turning.
Just FYI, I've driven 25K miles on clicking birfs, just don't abuse them (wide open throttle with wheels turned doing power slides) and you can milk them a long time to give you time to plan the replacement.
Well, I haven't had any clicking since the original shakedown run. Drove almost three hundred miles this weekend and did some moderate wheeling and no clicking. Either way at 220k might be a good idea to start saving for some new birfs in the future.
Well, it wouldn't be the wheel bearings cause I replaced those when I did the job. I didn't take the birfs apart I just soaked everything I'm kerosene and cleaned it as best I could.
If I'm not going to take them apart, I don't use solvent. Some grease is always left in them and any solvent contaminates that grease. We use a hypodermic type grease needle (like this http://www.amazon.com/Plews-05-037-Grease-Injector-Needle/dp/B000FMO6XU?tag=ihco-20), work it between the cage/ball into the back part of the birf. When new/thicker grease is pumped in, it displaces, pushes out the thinner old grease, replacing almost all of it without contamination while thoroughly packing them.
I then re packed them in moly lube along with the knuckles before re assembly. I've only driven it about 2-3 miles and the clicking was when I initially drove it. I didn't do it the last time I drove before I went out of town. I'll have to see what happens when I get back.
My guess; the active area wasn't properly lubed causing the clicking, as it was driven, the new grease worked into the birf, lubing it, and shutting it up. No guarantee that your birfs are good, but we have seen many times where dry or very low knuckle grease level caused clicking, bringing the grease level up and a driving a bit shut them up. Keep an eye on the grease level and an ear for the click, they maybe good?
