birf inner seal problem
Tallahassee, FL
Website
www.florida4x4.com
i got a problem with my passenger brif axle seal.
i have a newfield heavy duty axle and i did the marlin tac mod. i dont have the outer big clip at the outer stub either.
today i went to clean the birf out from some water contamination and i noticed that the inner seal was bent up top and ripped. i didnt notice any axle/birf damage.
also the bottom steering studs had backed out and i lost two of the sutds ..... i just checked those too :mad:. i am hoping this is where i got the water into the axle also.
do you think this is the possible cause of the seal damage.
thanks
Yes, a loose knuckle will tear up the seal.
thanks Dan. i got the short inner axle and new year hub plate and some other things from you ... maybe ill call you tues and order the update bolt stuff for that .....isnt there some kind of undated version for the studs?
thanks as always
Yep, the new studs are UBER nice. Very easy to install.
My bet- if two fell out, the other two are less than hand tight. That's what happened on mine.
You'll need a special socket tool to install the new studs. Check the Marlin site- they have everything laid out on there pretty clearly. Get their new heavy duty inner oil seal while you're there.... also uber nice.
