birf eliminator kit
Buckley, WA
So i'm fairly sure i'm going to be replacing the birfs in the next year or so be it from just wear or breakage. I saw the birf eliminator kit from marlin crawler and wanted some opinions on this and to see if anyone with an 80 has used it. Pro's con's to switch as opposed to staying with the birfs?? :cheers:
I think that kit is designed solely for the lighter yotas. I am not sure how long those Dana 44 u-joints are going to last on an 80, especially with 36s. . What's wrong with your birfs? If you are wheeling really hard, just get the stronger birfs with inner shafts.
probably what i'm going to do...... nothing really wrong with them yet, I just think they are original and with 200k on the clock i'll need some new ones at some time...... just saw the dana 44 conversion and thought it would be cool to have something other than the norm :D
Not sure how well exposed CVs are going to last on a full time truck?
DougM
DougM
You are right I never thought of that for some reason... still having trouble remembering the full time part :doh:
Don’t waster your money on u-joint style axles then long field is the only way to go.
The U-joint style put to much stress on the diff that’s why.
All our high bread axles we build have long field axles.
We have done lots of test on the U-joint axles there a waste of money.
Hope this will help
It does thanks
Not positive but that kit could be for the mini truck axles and the shafts would be too short anyway.
Things that are certain:
Modified mini-truck/pre 80 series spindles wont work.
Inner shaft lengths are different.
Possible problems in addition to the above:
Inner shafts require brass bushings pressed into the housing.
Outer shaft length?
Eliminator kit may be weaker than stock 80 series birfs?
ONly problem with longfields is with the "softer" metal, they will wear faster on a DD truck.
I don't think the longfields are softer metal for the 80 series, I'm not a metallurgist but I thought 4340 was fairly hard in the metal world. The CV Unlimited Newfields were softer due to the heat treating.
The Longfields are 4340 cromoly. MUCH harder and much stronger than the stock units.
this comment doesnt seem to be substantiated by the manufacture according to this. Anyone else have further input?
The Dana 44 uses the same u-joint as the Dana 30 axle - it is a major weak spot in Jeep front ends once you hit 35" tires, which is why CTM joints are popular with the hard core crowd.
Your stock birf is stronger than the Spicer 297-x joint you'd be replacing it with, even if it is in fact an option. Christo was saying on another thread that Longs for the 80 are stronger than CTM's for the 44, so nothing to be gained here.
I'd stay with the stock birfs on a daily driver truck. Remember, the 80 is a full time 4WD rig. If you want your stock birfs to last longer, get a part time conversion kit. But then again, that's more expensive than replacing the birfs every 200,000 miles.
Regards
Alvaro
