Birf colors -
Another question...
Is it possible to have a warped brake pad?
i think every lifted 80 I've had and ridden in alot have pulled to the right upon braking... NOT all the time, but occasionally. I feel it's just part of the steering being in a lifted 80.
Oh great!! You think brakes that occasionally pull to the right are OK huh? Hmmm, 70 mph someone pulls out in front of you hit the brake, now is your car going to (a) slow/stop in a straight line or (b) swerve right and hit the barrier......decisions decisions.......ah I know....where is my lucky coin?
If I had a warped rotor... wouldnt I feel it in the pedal? I dont get anything in the pedal... even when it gets "worse"... just in the steering wheel. QUOTE]
NO, think about it, if the piston is seizing in the caliper it cannot be pushed in and out by the warped rotor so instead of you feeling it through the pedal the brakes just go on and off making that side of the car go up and down.
If on the other hand the piston was NOT seized and the rotor was simply warped then yes the piston would be pushed back and forth into the caliper and the fluid pushed back up the brake line in to the master which you would feel through the pedal.
Personly I would unbolt and remove the caliper trying not to disturb the pistons put a block of wood slightly thinner than your rotor between the pistons and get someone to press the brake pedal down just slightly whilst you watch the pistons movement, the piston/s that do not move easily will be the ones that are binding.
Lift the rubber boots and look underneath at the pistons, nice and shiny fine, red rusty/flaked ect replace. BTW what colour is your brake fluid? If it is anything less than clear then it is contaminated with water which rusts the inside of the caliper, brake fluid absorbs moisture and the colour change is your indicator
At least you can discount the brakes this way and it costs nothing to check, make sure your pads can move freely in the caliper as well because this can cause the rotor to heat up as well, have you considered asking someone with a brake testing roller to check your brakes? Please note, if you mic the rotors it is not uncommon to find no distortion when they are cold.
regards
Dave
...what colour is your brake fluid? If it is anything less than clear then it is contaminated with water which rusts the inside of the caliper, brake fluid absorbs moisture and the colour change is your indicator
Reporting back in... let me know if I am off base...
Instead of replacing the bushings (as I originally thought... restocking fees :doh: ) it looks like I will be ordering a caliper rebuild kit and flushing the fluid
1. paper towel dipped in fluid resevoir (left) and new fluid poured on paper towel for comparison (right)
2. Pic of caliper pistons after doing the "board between pistons" test. Upper right piston wont move any further than it did and pad was much more worn on that side as well
:cheers: :beer:
Me too !!!!!!!
:cheers: :beer:
I just went thru' this same fiasco, almost identical.....
My brakes were bad, real bad. I decided to service/rebuild the entire system, every component that I could that was rebuildable...
The master cylinder was first. CDan sent me the rebuild kit and I did the magic. Cleaned up well, seals and pistons seem good, probably as good as day 1.
The rears were next. They were bad but they cleaned up OK and the the rebuild kit from CDan again worked it's magic. Many hours of cleaning and prepping but they seems as good as 'factory new' !
The fronts, a different story !!! I could not get 'any' of the pistons loose, not for all the tea in China. I tried all the tricks, compressed air, screw drivers either side, vice grips, nothting worked ! I gave up and called CDan again, sent him back the front rebuild kit, that was no longer needed, and ordered Toyota factory reman units.
I've also bled the system, probably 2 quarts in total have been pushed thru' the system. I even bled the lspv valve ! The original color was a dork honey, now it's crystal clear. I don't know in 17 years if my brake system has ever been bled or flushed. I always figured there was no way that contaminants could ever get into a 'sealed' system but I was so very wrong.:doh:
So now, my mission in life is to bleed/flush the system every year. It seems a little extreme but I've seen first hand what moisture and other 'bad stuff' in the system will do.
And to think, I let me :princess: drive around in my LC totally unaware !!!
Thank You for letting me vent !
Fluid is overdue for replacement
Indicating that the caliper pistons and or pads are siezed
:cheers: :beer:
If you are unsure what you are doing at this point seek advice from someone savvy with braking systems or, overhaul the caliper or replace, in the UK it is often cheaper in the long run to buy an 'exchange' caliper once you factor in the cost and time to overhaul plus warranty/lifespan ect.
It will be worth checking all calipers on your car as they all share the same contaminated fluid.
regards
Dave
