Birf colors -
Santa Cruz Mtns
Did some searching and came up with - pink is the shorter and green is the longer.
Has anyone found this to NOT be the case?
When I pulled the dust seal cap off(or whatever you call it)... the birf end was green. The one I have in my hand has a pink tip (:D no jokes)
I am trying to troubleshoot a problem and was going to swap in the pink birf that came with the truck. What I would like to avoid is a bunch of time spent just to find out there was actually an obvious answer.
Do I need to button things up and get the right birf? Or keep going and swap pink birf in?
I think the easier thing to measure would be the drive flange, at least for the birf still on the truck. Anyone got the specs on those?
Don't go by colors, go by measurements.
4/1994 and earlier: 238.5mm long birf.
4/1994 and later: 246.5mm long birf.
That's really the only definitive way to determine your birf cross-reference-ability.
Beno, thanks. This is exactly what I needed last night. It looks like the color on the end of the birf is certainly NOT a good indicator. The pink ended birf fit like a glove.
Tore everything down and swapped out the birf. Buttoned everything up 3 hours later. Not fast but... that did include calibrating my torque wrench, swap driver front and rear tires, lube 100 series pads, cleanup and a test drive.
Guess I am just practicing for my front axle service scheduled in 3 weeks. :D
Unfortunately, a bad birf was not my problem. The drive to work today confirmed that. I thought starting with a birf swap would be the "not just throw money at it" approach considering I had all the parts (also advised by Christo to look at this as a possible culprit.... thanks Christo :cheers:)
Problem...
When braking... I get a pretty noticeable steering wheel vibration/movement left to right. As I begin to slow the steering wheel movement decreases, almost like there are shallow "motorcycle woops" under the left front wheel, and the left front of the truck visible moves up and down in a static oscillation.
Now I am ordering new Slee control arm bushings and installing those as a next troubleshooting step. Any thoughts about what I described are always helpful!
:cheers: :beer: :cheers:
Sticking brake caliper pistons?
From your description, this doesn't seem too close but might be worth a check.
A sticking caliper piston on the front will cause a noticeable low pitched growl and drag to one side or the other at the very end of a stop. Mine happens in the 2-4mph range. Not always but maybe 10% of the time.
Mine pulls to the left when the growl happens, and upon inspection of the front left brake caliper there is indeed a crack in one of the piston seals. The crack leads to rust and other contamination that causes the piston to bind. I've ordered a rebuild kit from cdan and will have them apart shortly.
I've had the same problem on other vehicles and a new caliper or rebuild usually clears things right up.
Hmmm... good thought.
Didn’t see any tears in the boot but that doesn’t mean there couldn’t be a sticky piston.
I don’t get any pull either direction with this oscillation but... did notice that the issue seems to become more prominent after driving for a bit of time.
How much was the rebuild kit from cdan?
I think $25ish. I haven't received the goods/invoice yet but from what I remember the price was very reasonable and enough to rebuild both sides in the front.
Hmmmm another project :) I am starting to get more OEM parts lined up for projects that I have time!
:cheers:
The problem you describe is similar to a binding caliper piston, the piston does not retract properly after you have used the brakes. As you drive for awhile the discs heats up and starts to either get a hot spot or even distort, now when you brake you are seeing the front go up and down which is the pads running over the distorted or high spot on the disc.
To confirm this drive it until the brake are warm and then pull over and jack the front of the car up quickly and try spinning the front wheels, the culprit normally rotates and then falters as it hits the problem area.
regards
Dave
Taint got the specs, but I do carry one of each flange in my "spare" kit... only because I've needed both type before. Holding the different drive flanges in your hand makes it obvious. I'm also running different birfs/flanges currently, so maybe that's why i have a spare of each...
Yeah, it's obvious when you can see them side by side, or have seen both before. I was thinking to help the OP tell what was on his truck before he had to tear it down to figure it out (measure the birf) but apparently he was already into it.
Problem...
Am I the only one that thinks the rotors are warped??? I work in a shop, and see it all the time. Turn (machine if in spec) the rotors and slap them back on. Done it to mine. Shake is gone. Just my .02$
D
D
See post #9, I have aready said discs but of course you call them rotors, relax a little buddy have a :beer:
regards
Dave
I didn't see him as being worked up, but rather, just a statement.
i think every lifted 80 I've had and ridden in alot have pulled to the right upon braking... NOT all the time, but occasionally. I feel it's just part of the steering being in a lifted 80.
regards
Dave
Thanks for the info Dave.
If I had a warped rotor... wouldnt I feel it in the pedal? I dont get anything in the pedal... even when it gets "worse"... just in the steering wheel.
Either way... it sounds like a good test. In theory, is sounds like I should be able to see if its the caliper/disk or movement in the control arms.
Now you have me second guessing my decision to buy new bushings and the press tools ($150 Slee and $150 from Toyota) :rolleyes: Those frame side OEMs are SPENDY but Christo recommended OEM if you are wheeling the truck at all. He said the poly seemed to limit articulation.
I guess... in the end... I did end up throwing some money at it. Hopefully Dave 2000 test will allow me to return some spendy bushings/tools and laser in on the issue.
Thanks for info... new spare added to the tool bag when wheeling :cheers:
I didnt have anything to measure in mm so did the best I could with converstion tables online :D Have to admint I was a bit worried due to the paint color markings. Stood them side by side and all was good.
This original post went up pretty late in the evening (PST)... buttoned everthing up at 3:45am... I would have been VERY bummed putting this all back together with the same birf I took out. 6am came VERY quick that morning.
:cheers:
It's extremely useful when someone hands you thier spare birf from thier spares kit and you find it's not the same as yours (I've witnessed this)... most people carry spare birfs but not spare flanges to match... i now carry both!
I appreciate all the help guys. Had this truck at a shop I thought was really good (at least I know they are trust worthy)
They said it was the control arm bushings... said the rotors looked fine and they didnt think it was brake related.
If the rotor was warped, wouldnt it be felt all the time? Or does it depend on the how warped it really is? Also, I am not well versed with hot spots...
Good to know about the pulling... nature of the beast I guess.
The truck does pull the right a bit as it drives but, I dont get any excessive pull to right when braking
