Bilstein shock valving choice...
woody
Adulting: do not recommend
Staff member
Admin
SW Utah
have been running 14" stroke Bilsteins on all 4 corners with 255/70 valving
They now offer multiple options for valving....trying to decide to run the same valving on the new set or work with something different...either all 4 the same or different valving front and rear....
options:
255/70
298/36
270/50
from one Vendor site:
Rebound force is the first number, followed by compression force (rebound / compression)
Conventionally, the ratings are written as one tenth the damping force in Newtons.
EXAMPLE: Valve rating 275 / 78
-Rebound force is 2750 Newtons at 0.52
-Compression force is 780 Newtons at 0.52
255/70: This valving is designed for single shock application with a medium ride quality, ideal for replacement shocks. This shock is a great match for aftermarket lift kits. The monotube nitrogen shock offers significantly better ride characteristics than the typical hydraulic oil filled shock.
170/60: This valving is great for use in pairs for a double shock combination. This valving has a softer ride characteristic but when paired they offer substantial ride control.
anyone know of recommendations for the 3 valving options? Opinions?
Tkx!
My first question would be how does it ride for you right now and what would you like to change?
Does the rear end pogo on you at speed across bumps? Is it jarring?
Basically, how does the suspension do when you hit a big bump. How did the landings feel in the back end at Pismo?? :D
yes, the ride is jarring at speed...it isn't 'bad', but could be smoother....
I'm almost leaning 255/70 front and 270/50 rear....decisions decisions...
Pismo doesn't count, since the shocks were junk there :)
Pismo last year cowboy :D
how much do you use your front bumpstops?
270 50 rear sounds about right to me. Slow stuff you'll never notice the difference anyway..
those numbers are just for light cruisers .. coz I was thinking in something close to 400/80 .. ?
there is a formula based in your Cruiser weight ..?
BTW, Brian, also, remember that some of your Jarring at speed may be your limit straps (one front, one rear).
My 40's suspension is horrid with the winches loaded down..
