Bike rack
Nashville TN
I added a couple of bike racks to my roof rack on the 80. It turned out pretty good and only set me back about $40. I picked up a Yakima gutter and chopped it into 3 equal sections and blockhead fork mount. Drilled some holes and bolted everything to the rack. It holds the bikes securely and still leaves me room for other gear. The old Trek looks good with the 80 they are about the same age.
Looks good - now you need to invent a way to prevent driving rooftop bikes under low clearances. Something thousands of people a year find they need!!!
I switched to rear hitch rack after nearly everyone I know went through this and I left four black marks on my driveway one fine summer day that stayed that way by a foot and a half...
DougM
Not sure I will be able to fix that problem. Just don't forget the bikes are up there when you pull into the garage.
Very nice. Actually you can probably save the blockheads by using a pickup-truck bed fork mount (about $9)... Never the less good job!
As far as the clearance goes, I am with Doug. I heard someone killed his $2k+ bike when he passed through the bank drive-thru. Not to mentioned the damage done to the truck... I installed a home-made in-cabin rack - 2x4 with truck-bed fork mounts to clamp down the bikes. Works really well, assuming you don't need to transfer passengers and bikes at the same time.
Nice job on the rack.
After my :princess: killed my bike pulling into the garage I put on taller doors. :idea:
No more worries.
what are we looking at here? You got rid of the bikes? traded them for canoes?:D
nevermind, I SEE now, I was thinking you got smaller cars, ha ha.
No more worries.
You will also need to convince your bank to raise the drive-thru overhead, and garage for their roof. (not sure how you are going to do that. ) Be careful, don't ever hand your key to the valet parking attendant while you have your bikes on the top...
knock on wood I have not scraped my bikes off the top or rammed my kayaks into anything yet. I do believe yakima sells a magnetic device that mounts on your hood. At higher speeds it blows/folds flat but pops up as a warning when you slow down. I was going to give you a link but can not find this product anywhere.
knock on wood I have not s****ed my bikes off the top or rammed my kayaks into anything yet. I do believe yakima sells a magnetic device that mounts on your hood. At higher speeds it blows/folds flat but pops up as a warning when you slow down. I was going to give you a link but can not find this product anywhere.
If it happens it better happen only once. Twice and one would need to seek professional help. My work truck is just under 11' and I have had no trouble with clearances. You just need to be aware of your surroundings. That gas-tank sticker is sweet!!
Cheers
