Bib hinge bolt size?
Captn Conch
Life Begins Above Timberline.
4 Corners New Mexico
Just noticed I'm missing one bolt that attach the bib hinge to the bib, these are the 2 front facing bolts, the remaining bolt has the number 5 on the head but I need to know what size it is. I searched my bolt inventory and no #5 bolt to be found. need length and thread type info. I figure if I go the hardware store I wont be able to fit a bolt in there as it may be just enough out of alignment to do a parking lot thread test.
I'm afraid to pull the remaining bolt out as it may not go back in without some realignment efforts.
8mm x 1.25, 20mm
Thanks Guys! I got my little extension mirror and looked behind the hole at the bolt. My remaining bolt has washer and lock washer on it. I thought it had a capture nut setup. Now I gotta lift or remove the radiator to get access to the backside. Seems like it should have been the capture nut situation d/t location.
