- Thread starter
- #21
What took so long?
Since you asked....
Well first I got the spring mounted to the truck but couldn't get it to seat on the axle. Tried some little ratchet straps to pull it forward to no avail. So then unhooked the pivot end and monkey'd with the axle to get the spring pin to seat, then realized the u-bolts were about 2 inches to long to run down with my deep well. Also realized that I have jack for standard tools and need to invest in some good 6-points in 1/2" drive. So after running the u-bolts the last inch or so with a box end, but still not getting it seated all the way, we tried unsuccessfully for what seemed like forever to get the front fixed end bolt back in. Finally gave up and decided we should unbolt the shackle end and start completely over, but discovered that in all the shaking the truck was trying to shift and was getting tippy on the Jack stands, so had to break out the hi-lift and monkey with all the stands to make sure everything was safe. With that addressed it was back to trying to get the fixed end back in, eventually had an epiphany and remembered the heavy duty straps for tying down the sami, used one of those and a pry bar to wrangle the fixed end into place. Then with that in we moved to the rear. The ford has those inverted shackles so trying to get them back in was a fight. We had the axle free hanging on the spring and one bolt and couldn't get it to settle in.. back to the pry bar and a c-clamp to get the bolt hole lined up. Finally we got it lined up and Erin drove the shackle bolt home. Tightened everything down, put the tire back on and cleaned up. I also feel that all this was compounded by the fact that my driveway work area is slightly sloped and gravity was also seeing what kind of misery she could throw at me as well. All in all I learned enough so that hopefully the drivers side will go much smoother.
Worst part is the rear was supposed to be the easy end, God only knows what awaits me when I dive into the TTB front end.
I also found that the e-brake doesn't work (knew that already) because some dingle berry cut the cables loose and had them tucked into the frame rails.... the rear brakes look to be in decent shape so I figure rebuilding them and repairing the e-brake can wait.
Will finish up the rear and then head over the Marta for the old sniffer test. Hope to have her on the road soon.
could tell her about her first day at pre-K.
