Best way to pull a 3FE
Provo, Utah
Just as the title says, what is the best way to pull the 3FE out of my truck? Is it best to separate the engine and transmission first or yank the whole thing out as one unit? I need to replace my engine and just wanna know if it would be better for me to drop the transmission first. Thanks for any input.
With a 1FZ-FE or better. Gonna need some power.
Sorry, that was too easy. you left it wide open.
afaik you pull the engine with the transmission.
Pulling the engine with transmission would make the whole project go more smoothly. You will more than likely waist more time trying to maneuver the engine out and the new one back in with the transmission detached. Then you have to try and get the torque converter pilot to line up or get the torque converter to line up and go Into the pump correctly without damaging it. Depends on how you take it out seperately. If you take it all at once you can do all of that out of the truck with ample work space and it's not a whole lot more work.
