best trans
NH
First let me say high to every one and let you know I am new to this land cruiser thing. I think I know the answer to this question but I thought I would ask the people that would probably know best. I'm putting a 1995 fj80 frame and axles under a 59 willys jeepster and I putting a 6.0 LS in it and I was wondering if I should change the bell housing and use the Toyota tranny or put a transfer case adapter and use a 4l80e trans. Also would it be better to part time my transfer case or find a different one.
IMO you should mate the LS to a 4L80E (make sure you get the 4WD tailhousing), then to a compatible GM transfer case. This simplifies a lot of things. You can change shift points by reprogramming alone, the entire package will be stronger without adapters in the way, you don't have to hunt for adapters, the GM parts are easier to get/cheaper when you break something, no issues with harmonics, speed sensors are already taken care of, and mounting is easier when you're not juggling OEM hardpoints with your LS ones.
From there all you need are custom dshafts which can be made anywhere.
Whatever you do go with an electronically controlled trans. I am so done screwing with the throttle valve cable on my 700r4. I have to build a new (correct) throttle pulley to correct the original setup and I'm hoping my 3-4 clutches aren't fried right now.
Wouldn't the offset rear axle be a problem with the center out put of the gm transfer case?
I figured you wouldn't be using the stock gas tank. If you want to do that, the tank will have to go higher or the powertrain will need to be mounted lower. The tcase output would be right in front of the stock tank.
From eyeballing my cruiser, I think having the driveshaft in that arrangement is feasible. Your safe CV joint angles will be limited by RPM. A max of 8 degrees on each should keep you safe up to roughly 3000rpm. This is a very rough guess and contingent on the quality of your driveshaft.
There's nothing wrong with running the CV joints at an angle. The priority is keeping the tailshaft and pinion centerlines in parallel. If that's done, then a small angle will actually help prevent sympathetic vibration and keep from mulching your bearings.
I'm getting distracted though. FJ80 tcase to 4L80E would work fine and with less messing about than adapting a yota trans to a GM engine.
If you have the $$$ that is.. 50-1702 : GM 4L80E to Toyota Land Cruiser HF2A Adapter Kit | Advance Adapters
Good luck with your build! Be sure to update us on here.
My cousin is currently running a 22r and Toyota 5 speed and transfer out of a taco in his 53 willys. He isnt having issues with the offset. And the original axles are both passanger diff. His rear driveline is only like a foot long though and double- double cardan's
All of the 80 series LS swaps I've heard of use a GM trans (4L80 or 4L60) mated to the stock t-case. I would be inclined to go that route.
Well my decision was made a little easier today! I bought an 06 6.0L and a 4L80. I have been searching for transfer adapter and Marks is all I can find. Does any one know of any other?
