I'll take quality down bags for 200, Alex.
I checked the specs on my deep cycle battery and the bunk warmer. The battery is a 95 amp hour and the bunk warmer uses 8 amps an hour. According to the website of the heater it only cycles on 50% of the time at most, so they said to figure 4 amps per hour. Given those figures the bunk warmer should work for about 24 hours straight. If you ran it for 8 hours a night (I don't think I have ever slept a full 8 hours camping) you should get three nights out of a charged battery. One of the drawbacks to the bunk warmer is it only warms up the sleeping bags and not the air in the tent. Not sure if this is a big deal but it might be for some people. Hope this helps![]()
Great point!
I had to give her mine and spoon to keep her warm. I ended up freezing instead that night.
You HAD to give her yours!??! Randy Randy Randy. You should know better. Never let your girl get cold. You should have went to HER for warmth![]()
If money was not an issue I would put one of these mini-furnace heaters in my FJ60 and run a duct up to the RTT. They can run on gasoline of deisel.
BlueHeat® Air Heater Specifications
Mark
I have owned 3 Mr. heaters and they work great. I have used mine at -5 degrees with no problem. I have used it in my new house when there was no power. We just cracked a window a bit to vent the CO.Well, it sounds like the Mr. Heater may not be an option. I appreciate the input.
FYI - The Lowes by me in the Dallas area is closing out their heaters including both sizes of Mr. Heater at 50% off.
I use this foil-bubble wrap insulation stuff under my sleeping pad on the floor of my Oasis RTT It Helps. Heck on a cold night you could put a sheet over you too.
Astrofoil reflective insulation-residential and commercial
You can get it at Home Shleppo
Mark
