Best knuckle upgrade?
Sacramento, CA
Checked FAQ and searched, couldn't find it...
What is the best knuckle upgrade for a 76 40 axle? Actually, lets say a 73. I am going to swap the guts into a housing that is set up for SOA pretty soon (from 76 to 73) and want to get all of the steering done right as well. What knuckles should I get? Should I just find some of the larger stud later cruiser knuckles, and minitruck knuckles, or should I buy aftermarket, or wait for the 6-stud knuckles (;p i kid, i kid)?
What do you guys think and what worked for you?
I will be running (hopefully) Lukes 4x4 labs steering arms and maybe either 35's or 37's. Eventually an ARB in the front, too. Just let me know, thanks.
-Eric
No LC knuckle can match a D60 knuckle in strength:
79-85 minitruck/79-90 land cruiser knuckles are the same.
I prefer simple marlin style hysteer arms where the draglink attaches to the passenger side tie rod end.
getting ARP knuckle studs and keeping them torqued properly will be the best strength upgrade you can make.
95% of knuckle probems are due to loose studs.
We just did mine. Put mini knuckles on. I am using Lukes kit also. We drilled the knuckles and the high steer arms out to accept D44 (9/16) studs and cones. Luke said he is planning on making the arms with adaption soon, as of 2 weeks ago, he was just waiting for the tooling. Cruzila has been guiding me and did my machine work. He may still be offering to do others as a swap out. You'd have to check with him. We found the U-bolt long style nuts work great. they completely cover the longer D-44 stud and look really nice. I'll try to get some pics soon.
Also, the initial set of Lukes arms didn't work for me. We moved the axle forward and are using FJ60 rear springs. The tie rod just barely hits. Luke also has, and was awesome enought to send out, a set of high offset arms that I don't think are on the site. Good luck
