As my understanding, most of the automotive use "Starting" batteries, which are designed for delivery large current in a short time. They are good for starting and running engine, but not very good for "deep cycle". That's why your battery dies quickly if you keep forgetting to turn off the overhead in-cabin light. On the other hand, the "Deep cycle" which allows to draw down up to 80% on each discharge can't deliver as much crank amp as the equivalent Starting batteries. That's the reason that it is recommended to use 20% larger capacity if one decide to use Deep Cycle battery also for starting...
IIRC, optima yellow is a deep cycle battery, it will be good as a backup for stereo amp, winch etc. But if you are use it to drive the starter, you might need a larger one (if it exists). So save yourself some money, try the red top (starting battery), or blue top (marine battery - between starting and deep cycle) if you have a large numbers of accessaries. That's said guys here (me included) seem to be happy with the DieHard Platinum. It's a bit pricer but not too much comparing to the Optima blue.
You have the yellow and blue tops confused. The blue top is deep cycle and the yellow is in between. It has plenty of CCA to do the job of starting the vehicle.
Thanks once again for your help...
