Bent tie rod
Fayetteville, AR. " The Hill"
I bent my tie rod today, and I wash wondering what is the best way to fix it without buying a new one?
Cut the ends off and push them into a piece of 1 inch, schedule 40 pipe. get about 6 inches of overlap at each end and weld it together. Simple and cheap. Oh yeah, stout as heck too.
Mark...
Mark...
They are stock tie rods. I tried to pull them off but Couldn't get it . Is there any special tool to do so?
the 1" pipe works good most hardwares around here have short pieces if you dont semper fi
Or buy a new TRE from the dealership and get one for free :)
Sleeving will be stronger tho..
I got extras now...
:D
Alignment shop couldn't straighten my bent one :confused: , they just adjusted it as is. It seldom rubs so I guess it's OK.
If it's really bad just replace it, no biggie.
CruisinGA said:
Do you plug weld as well as weld around where the pipe overlaps the ends?
Not really necessary, You could tack the sleeve on and it would help..
All the pipe has to do is add strength in bending, not extension..
I just had a drag link modified. The company that sold me the weld in bung, Spidartrax, recomeneded cross drilling and welding. The guy that did the work did that, but also fishmouthed the sleeve section to add more weld length.
I think you are assuming he is sleeving the whole old tie rod. If he cuts a section off each end and replaces the center he will need welds.
Mark...
That's what I did and it works great. I actually drilled some holes in the 1 inch pipe about 1 - 2 inches appart then push the tie rod through and welded the ends and in the holes.
- Rico.
Didn't even see that Mark said to cut the TR.
Sorry bout that, my mistake.
