bent front axle shaft??!!
PNW
ok, so I purchased a 1991 FJ80 from a young couple in Denver, CO. this summer. When I purchased it, it was supposed to be strictly a daily driver. when I test drove it etc. I never ran it above 50 mph. here's where it gets interesting. on my way to Lubbock, TX one day after purchase, I noticed that it had a serious vibration on the right front corner when I went above 60mph. Well i automatically assumed tie rod ends, wheel bearings, tire rotation, balance and alignment. but wheel bearings were still in the back of my mind, also the the steering stabilizer. so once I got it here, i took care of all of the above minus steering stabilizer and wheel bearings. I drove it from Lubbock,TX to Roswell, NM and the vibration was just as prominent as ever.
now I have to ask, could it be more serious than all or that and the wheel bearing and stabilizer? I've jacked up the front end and pulled on the wheel and it isn't giving the standard wheel bearing slop that most vehicles show.
is this possibly a bent axle shaft? what is the likelyhood of this? :confused:
Not likely. The wheel is not supported by the axle shaft. The wheel itself might be bent, but a balancer should pick that up. Have you rotated the tires?
-Spike
ok, so I purchased a 1991 FJ80 from a young couple in Denver, CO. this summer. When I purchased it, it was supposed to be a strictly a daily driver. when I test drove it etc. I never ran it above 50 mph. here's wher eit gets interesting. on my way to Lubbock, TX one day after purchase, I noticed that it had a serious vibration on the right front corner when I went above 60mph. Well i automatically assumes tie rod ends, wheel bearing, tire rotation, balance and alignment. but wheel bearings were still in th eback of my mind, also the the steering stabilizer. so once I got it here, i took care of all of the above minus steering stabilizer and wheel bearings. I drove it from Lubbock,TX to Roswell, NM and the vibration was juat prominent as ever.
no I have to ask, could it be more serious than all or that and the wheel bearing and stabilizer? I've jacked up the front end and pulled on the wheel and it isn't giving the standard wheel bearing slop that most vehicles show.
I doubt that you have a bent axle shaft. It's either straight or it's busted. Look at things like worn bearings, spindles, spindle bushings, lack of grease, or out of balance tires.
-o-
i have had the tires rotated and balanced. the tires were rotated from front to back because they were cupping really bad. so i also thought this might also eliminate the idea that I have a bent wheel. they are stock. i'm used to aluminum breaking before bending. am i correct in this statement? could this be driveshaft related?
I made sure that the knuckles were greased before i even drove it from Colorado to Texas. that was a high priority issue with me since i know that most cruiser owners have no idea that it needs to be done. I also greased anything that had a zerk fitting to put a grease gun on.
Yep, rotating the tires eliminates balance and bent wheels, if the vibration is obviously coming from one corner and it doesn't change with the rotation. I would do a careful inspection of that knuckle and steering components, make sure all the nuts and other fasteners are tight especially on the trunnion bearing caps, tie rod ends aren't flopping around, that sort of thing. Check the shocks as well.
-Spike
Check you front panhard rod. I had some serious vibration due to the panhard being loose. A side note...the steering would be a little "loose" if it was the panhard.
Matthew
i have checked the knuckles over very well. I inspected the caps and checked the nuts on the bottom of the steering arms. it is all tight. I have not checked the panhard rod yet to see if it's moving around. I will make a note of that. as far a shocks go. could this be caused by shocks. when I drove it from Roswell, NM back to Lubbock, TX. It threw off the wheel weights from inside the passenger tire. this is why I'm thinking that it is limited to the one side. the drivers sides doesn't shake nearly as bad as the passengers. the only vibration that I get in the wheel is directly related to when the right side begins to shake. could an out of balance drive shaft do this?
An out of balance drive shaft wouldn't show up on one wheel, and the driveshaft doesn't have enough mass to throw a wheel around enough to blow the weights off. The shock should be limiting the bounce, and it sounds like it's not. If it were completely toast then there's nothing to dampen the road bumps at that corner, and maybe the wheel is acting like a basketball. Is the vibration steady, or does it come and go, or pulse? Would you say it's vibrating or shaking?
-Spike
Try taking the shock off and checking it out. The fact that your tire is cupping is a sure sign of shock failure. Wearing on one side of the tire or pulling to one side usually means alignment problem or a problem with the parts that should hold the wheel in alignment.
the tire is certainly shaking. i didn't figure that the driveshaft would have enough mass or movement to create the amount of shaking i'm getting from that side. I'm gonig to pull off the pan hard and check it out, and then I'll also pull the front shock to see if that eliminates any of the shaking. thanks for the input. i'll keep everyone informed. :cheers:
also, the shaking comes and goes as it feels necessary. but it usually wont show signs until approx. 60+ mph. thats why i didn't notice it when I was test driving it before purchase. if it ends up being shocks, I might just wait until I purchase a lift and shocks and new tires. anyone selling a ome 3.5" lift for cheap...???
Pull the shock and check it. It should have a lot of resistance to both push and pull. Just removing it won't tell you anything, because if it's bad it's acting like there isn't a shock there now. Also, you shouldn't have to pull the panhard to check it, just grab it and see if there's any movement at all. Again, the panhard would effect both sides the same way, so I doubt that's your problem but it's possible.
-Spike
well moving the panhard by hand showed no visible signs. like before. maybe I'l pull it off to inspect any additional wear patterns where it bolts up to. some shiny spots or worn bushings. also, tomorrow I'm going to pull the shocks and establish if they are bad or not. from left to right. I know how a shock is supposed to work and if it isn't right, then I'll know. hopefully this is a cheap fix. i couldn't imagine anything else that it would be other than wheel bearings and races.
