Bent front axle housing
peth
Hey guys
my axle seal was leaking large amounts of oil into and onto my rims and brakes so i decided to change it
No worries $23 for the oil $6 for the seal
Water of a ducks back
pulled it all down till the part came of removing the cv shaft/ axle
wouldn't come out with a decent pull
quickly realized something was wrong
and oh how it is
axle housing is so bent the cv joint wont come out the end of it
without a hammer and pry bar as it fouls on the bottom of the housing
so my question is this a normal problem for these things
and will a solid axle 100 series front axle housing work as a replacement as i have 1 laying around
IIRC, both the 105 and 80 series use the same front axle.
Just make sure it's for a RHD application. The track bar (panhard?) mounts are different between RHD and LHD.
Out of curiosity, what have you done lately that may have bent the housing like that?
yea its from a rhd
i haven't done to much 4wd recently but if any thing it might be wedge track that did it hmm
oh well good weekend killer
thanks for your input guys
The axle from the 100/105 should fit, then.
I would invest in a gusset or some sort of bracing for the knuckle balls. Like what Kernal just posted.
yea looks like the way to go if done right
i don't know if i will be able to just put another diff in without doing something
well i have a arb air locker sitting around that i was putting of putting in but looks like time has come
sooner rather than later
What's a 'wedge track'?
DougM
